![3A Unipolar Stepper Motor Driver 3A Unipolar Stepper Motor Driver](https://www.electronics-lab.com/wp-content/uploads/2015/11/M031_2-1024x804.jpg)
This tiny Unipolar stepper motor driver has been designed around SLA7078MPR IC from Sanken, It is unipolar stepper Motor driver can handle current up to 3 Amps, micro-stepping up to 1/16 steps. On-board Jumpers to set the Micro-stepping, Preset (Potentiometer) to set the current.
The SLA7070MPR series motor driver ICs features unipolar drivers. The clock-in type input interface allows simplified control logic, and options for built-in sense current detection and load circuit short or open protection (patent pending) provide lower loss, and lower thermal resistance.
The built-in excitation distribution circuit (sequencer) allows motor control using only the CLOCK signal for simple operations (rotate/stop), with motor speed control by frequency input into CLOCK pin. This eliminates logic signal lines required for conventional phase-input methods, and reduces demand on heavily-used CPUs.
Unipolar stepper board is high efficient stepper driver for Unipolar stepper motor been design for various application like robotics, control routers, lathes, mills, PCB drillers and engravers.
3A Unipolar Stepper Motor Driver – [Link]
Hello,
I’m need to buy 3A UNIPOLAR STEPPER MOTOR DRIVER and I would like to know if you have software for Unipolar stepper motor. I need simple progammable software. Please let me know if you have software or link to download this software. Thanks, Sam
You can buy this as a kit at http://www.kealab.com but you have to use your own controller and software in order to control a motor. Thanks
