Forlinx Embedded Launches New FET-MA35-S2 SoM Based on Nuvoton MA35D1
SoM-CoM
Nuvoton's NuMicro® MA35D1 series microprocessors have become the engineers' trusted choice for high-end industrial control, edge IoT gateway, and HMI applications due to their high-performance multi-core heterogeneous design, reliable security mechanisms, rich communication...
MYIR Introduces the MYC-LT536 System-On-Module
SoM-CoM
Measuring only 43mm by 45mm, the MYC-LT536 is a compact System-On-Module (SOM) based on the Allwinner T536 processor (T536MX-CEX/T536MX-CEN2). It boasts a quad-core ARM Cortex-A55 CPU running at 1.6GHz and a RISC-V E907 MCU operating at 600MHz. The module supports a 2Tops NPU (only for...
Orange Pi 4A SBC: Powered by Allwinner T527 with Mali-G57 GPU and 2 TOPS NPU
SBCTop Stories
The OrangePi 4A is a cost-effective single-board computer (SBC) designed for industrial applications. It is equipped with the Allwinner T527 octa-core Cortex-A55 processor clocked at 1.8GHz, a HiFi4 DSP, and a multi-core E906 RISC-V processor running at 200MHz. The board also features a...
EPDK-Matter Kit is a Arduino Nano ePaper display development board with Matter support
ArduinoLCD/OLED/ePaper
Pervasive Displays has partnered with Arduino and Silicon Labs to launch the EPDK-Matter development kit. This Arduino Nano ePaper display combines a 2.9" black-and-white ePaper display with Matter home automation support. The kit features a 384×168 pixel display, EXT4 Expansion board...
$120 Raspberry Pi 500 Desktop Kit features A BCM2712 SoC and comes with 15.6-inch Raspberry Pi Monitor
Raspberry PiTop Stories
Raspberry Pi Foundation has recently launched the Raspberry Pi 500 Desktop Kit, which includes a Raspberry Pi 500 keyboard and a 15.6-inch Raspberry Pi Monitor. Previously they have launched the Raspberry Pi 400 which was also a keyboard PC. But the new kit 500 500 features a much...
Arduino Nicla Sense Env: Environmental Sensing for Smart Applications
IoTSensorTop Stories
Continuous environmental monitoring is becoming more common in many industries, but it often requires collecting data all the time, which can use a lot of power. The Arduino Nicla Sense Env aims to address this challenge with its compact design and low power consumption. This makes it...
Making IoT more user-friendly with STDES-WL3x microcontroller designs
IoTTop Stories
In today’s IoT industry, there is an increasing need for faster and more robust microcontrollers to support the demands of complex IoT systems. To meet these demands STMicroelectronics NV which is a major semiconductor designer and manufacturing company has introduced the STDES-WL3x...
Signaloid C0-microSD Is A Compact Programmable FPGA SoM in MicroSD Form Factor
FPGASoC-SiP
The Signaloid C0-microSD is built around Lattice Semiconductor's iCE40UPK FPGA, designed to provide versatile computing options for systems with limited expansion capabilities. It can be used in two major configurations: a hot-pluggable FPGA module or a hot-pluggable co-processor...
