Renesas RRH62000 Air Quality Sensor Module with I2C/UART Interfaces and Built-in Processing
Sensor
The Renesas RRH62000 series is an integrated sensor module that measures air quality parameters like particulate matter (PM), total volatile organic compounds (TVOC), Indoor Air Quality Index (IAQ), estimated CO2 (eCO2), temperature (T), and relative humidity (RH). It gives digital...
SparkFun Pro Micro-RP2350: Dual-Core Cortex-M33 and RISC-V Microcontroller Development Board
McuRaspberry PiTop Stories
The RP2350 is a dual-core microcontroller featuring two ARM Cortex M33 and two Hazard3 RISC-V processors, with a selectable boot option for any two cores. It operates at 150 MHz, has 520 kB SRAM in 10 banks, and includes peripherals like two UARTs, two SPI controllers, two I2C...
RP2040-Touch-LCD-1.69: Featuring RP2040, QMI8658 6-Axis Sensor, and ETA6096 Li-Ion Recharge Circuit
LCD/OLED/ePaper
Waveshare's RP2040-Touch-LCD-1.69 is a compact MCU board built around Raspberry Pi's RP2040 microcontroller. It features a dual-core Arm Cortex M0+ processor running up to 133 MHz, with 264KB of SRAM and 16MB of Flash memory. The board includes a 1.69-inch capacitive touch display, a...
MOTION 2350 Pro: The Ultimate Beginner-Friendly Robotics Controller with Advanced Capabilities
Raspberry PiRobots
Cytron has recently launched the Motion 2350 Pro an advanced robotic controller powered by the Raspberry Pi for building advanced robots with less effort. It has the latest upgraded RP2350 processor, which is the successor of RP2340. The controller also has an advanced DC motor...
ASUS N97T-IM-A Thin Mini-ITX Motherboard with Intel Alder Lake-N N97, DDR5, Dual LAN, and Multiple Display Support
SBC
The ASUS N97T-IM-A is a Thin Mini-ITX motherboard built for industrial and embedded applications, powered by the Intel Alder Lake-N N97 processor with 4 cores (2.0-3.6 GHz). It supports up to 16GB of DDR5 memory at 4800 MHz and features dual LAN ports with Realtek RTL8111H controllers...
HACS, Music Assistant, and microWakeWord Join Forces with Open Home Foundation
Miscellaneous
The Open Home Foundation is working with more partners like HACS, Music Assistant, and microWakeWord to make smart homes better. They're focused on keeping things private and letting users decide how their smart homes work. They want to ensure Home Assistant stays free and can't be...
LILYGO T-ETH-Elite: An ESP32-S3 Board with Stackable LoRaWAN and Cellular Expansion Modules
IoT
LILYGO has introduced the T-ETH-Elite, an ESP32-S3-powered IoT board featuring an Ethernet RJ45 port with Power over Ethernet (PoE) support and a 40-pin GPIO header for stackable shields. This board is designed for building IoT gateways with versatile connectivity options, including...
WP-UT5 Adapter with Realtek RTL8157: High-Efficiency 5Gbps USB 3.2 Networking Solution
USB
The WP-UT5 adapter, featuring the Realtek RTL8157 chip, supports network speeds from 10 Mbps up to 5 Gbps while consuming less than 1.5W. It's compatible with USB 3.2 Gen1/2 and works with Windows, Linux, and macOS. The adapter adheres to IEEE 802.3bz (5G Base-T), supports VLAN tagging,...
