![Neuron-1 is A 5-Axis CNC Motion Control System with RJ45 Connectors and Plug-and-Play Functionality Neuron-1 is A 5-Axis CNC Motion Control System with RJ45 Connectors and Plug-and-Play Functionality](https://www.electronics-lab.com/wp-content/uploads/2024/07/2U2A1277-V1-1024x683-1.jpg)
Neuron-1 is a universal 5-axis CNC motion controller used to control CNC machines, such as milling machines, routers, and lathes, and the most unique thing about this board is that it uses RJ45 connectors to make a plug-and-play system. The board is based on Teensy 4.1 and includes a...
Continue Reading![Infineon CY8CKIT-062S2-AI PSoC 6 Edge AI Evaluation Kit is Built for Seamless AI Integration in Embedded Applications Infineon CY8CKIT-062S2-AI PSoC 6 Edge AI Evaluation Kit is Built for Seamless AI Integration in Embedded Applications](https://www.electronics-lab.com/wp-content/uploads/2024/07/CY8CKIT-062S2-AI_KIT.png_2013019694-e1721107248839-1024x692.jpg)
Infineon CY8CKIT-062S2-AI Evaluation Kit is a Hardware platform focused on Machine Learning (ML). Built around the PSoC 6 family of MCUs this dev board includes sensors like radar, microphone, magnetometer, IMU, air pressure sensor, and much more. The board features Wi-Fi and Bluetooth...
Continue Reading![Sipeed Lichee Book 4A 14″ Modular Linux Laptop with TH1520 Quad-Core RISC-V Processor Sipeed Lichee Book 4A 14″ Modular Linux Laptop with TH1520 Quad-Core RISC-V Processor](https://www.electronics-lab.com/wp-content/uploads/2024/07/lichee-book-4a-um-laptop-risc-v-com-chip-e-memoria-atualizavel-1-1024x566-1.webp)
Sipeed Lichee Book 4A is a RISC-V lightweight laptop featuring a 14-inch 1920x1200 display, RISC-V TH1520 SOM (8+32/16+128 options), and various connectivity options including USB-A, USB-C, SSD slot, and more. It is designed for RISC-V developers to explore real-life applications of...
Continue Reading![AAEON Unveils New RISC Computing Line Powered by Texas Instruments AAEON Unveils New RISC Computing Line Powered by Texas Instruments](https://www.electronics-lab.com/wp-content/uploads/2024/07/PICO-AM62_3DFront_02-1024x805.png)
Compact, environmentally resilient, and incorporating Texas Instruments AM62x Sitara Processors, the PICO-AM62 & SRG-AM62 show AAEON make big moves in cost-efficient RISC-based computing. AAEON, a leading provider of compact embedded solutions, has announced two new additions to...
Continue Reading![AAEON Debuts AQ7-ADN Qseven Module Featuring Intel Processor N-Series & MIPI Camera Support AAEON Debuts AQ7-ADN Qseven Module Featuring Intel Processor N-Series & MIPI Camera Support](https://www.electronics-lab.com/wp-content/uploads/2024/07/pgal_240710_z1uh93.jpg)
The AQ7-ADN extends AAEON’s adoption of the low-power Intel platform across its Computer-on-Modules range. Having recently adopted the Intel Atom® Processors x7000E, Intel® Processor N, and Intel® Core™ i3-N305 platforms to a number of its Computer-on-Modules, AAEON has...
Continue Reading![MYIR Launches New SOM Based on Rockchip RK3568 Processor MYIR Launches New SOM Based on Rockchip RK3568 Processor](https://www.electronics-lab.com/wp-content/uploads/2024/07/myirlr3568som.jpg)
MYIR has launched the MYC-LR3568, a cost-effective System-on-Module (SoM) that is powered by the high-performance, low-power quad-core ARM Cortex-A55 processor RK3568 from Rockchip. This SoC boasts robust Mali-G52 2EE GPU capabilities and supports up to1 TOPs NPU.It also supports...
Continue Reading![RealTek RTL8126 5Gbps Ethernet Card Costs $12 and more RealTek RTL8126 5Gbps Ethernet Card Costs $12 and more](https://www.electronics-lab.com/wp-content/uploads/2024/07/RealTek-RTL8126-5Gbps-Ethernet-M2-card-1200x1141-1-1024x974.jpg)
The Realtek RTL8126 is a 5Gbps Ethernet controller IC designed for high-speed networking applications. It's designed to be a low-power, cost-effective product that brings 5Gbps Ethernet connectivity to devices like desktops, laptops, and servers. The IC was first unveiled at Computex...
Continue Reading![Pico Display Base Board – A Versatile Platform for Raspberry Pi Pico based LCD Projects Pico Display Base Board – A Versatile Platform for Raspberry Pi Pico based LCD Projects](https://www.electronics-lab.com/wp-content/uploads/2024/07/2024-06-06T19_46_45.510Z-Reading_Stopped-1024x682.jpg)
The Pico Display Base Board is a compact PCB board designed to simplify the creation of projects using a Raspberry Pi Pico and an LCD screen. The board includes onboard components like buttons and LEDs, as well as ports for additional modules like an RTC module, OLED display, or...
