![Argon ONE V3 M.2 NVMe Case Improves Raspberry Pi 5 Argon ONE V3 M.2 NVMe Case Improves Raspberry Pi 5](https://www.electronics-lab.com/wp-content/uploads/2024/06/Argon-ONE-feature-image.png)
MPUs fulfill the ever-growing demands and needs of IoT and embedded applications. However, these MPUs are built for specific uses, and they do not exhibit expansion for future scopes. Several extensions are employed to meet these needs. One of these extensions is launched by Argon40, a...
Continue Reading![The Pi5 Connector supports Raspberry Pi5 and Pi4B The Pi5 Connector supports Raspberry Pi5 and Pi4B](https://www.electronics-lab.com/wp-content/uploads/2024/06/Pi-5-connector-ft-image.jpg)
Transmission of audio and visual signals without distortion plays a significant role in communication and electronic systems. While efficient devices are required for such transmission, the interfacing of the development board is not achieved easily. For this purpose, connector...
Continue Reading![Ochin CM4V2: Tiny Carrier Board V2 for Raspberry Pi CM4 Ochin CM4V2: Tiny Carrier Board V2 for Raspberry Pi CM4](https://www.electronics-lab.com/wp-content/uploads/2024/06/Ochin-v2-feature-image-1.jpg)
The industrial setting often calls for advanced performance while minimizing the circuit size. As Ochin V1 is reaching its end of life (EOL), Ochin v2 is a new mini carrier board for Raspberry with numerous advanced features over its preceding version. The Ochin CM4v2 is a compact...
Continue Reading![AAEON’s PICO-RAP4 Harnesses 13th Gen Intel Core Processing on the Tiny 2.5” Pico-ITX Form Factor AAEON’s PICO-RAP4 Harnesses 13th Gen Intel Core Processing on the Tiny 2.5” Pico-ITX Form Factor](https://www.electronics-lab.com/wp-content/uploads/2024/06/PICO-RAP4_3DFront_01-1024x714.png)
Power-efficiency, real-time data processing, and synchronized interfaces make the PICO-RAP4 a small board for big projects. AAEON, an industry-leading provider of embedded solutions, has announced the latest addition to its line of PICO-ITX boards: the PICO-RAP4. Equipped to host CPUs...
Continue Reading![ThingPulse Pendrive S3 – A ESP32-S3 Pendrive with RGB LED, Wireless Storage and Much More ThingPulse Pendrive S3 – A ESP32-S3 Pendrive with RGB LED, Wireless Storage and Much More](https://www.electronics-lab.com/wp-content/uploads/2024/06/PendriveS3_PCB_Top-2-e1719232785872.jpg)
Though it's called a Pendrive, the ThingPulse Pendrive S3 is not your average drive it's a versatile device that can transform into various USB gadgets, like a memory stick, keyboard, mouse, or even a networking tool. But its most intriguing use? It can be a "BadUSB" with the...
Continue Reading![Mixtile Zigbee and Z-Wave 2-in-1 mPCIe Interface Cost Only $19.90 Mixtile Zigbee and Z-Wave 2-in-1 mPCIe Interface Cost Only $19.90](https://www.electronics-lab.com/wp-content/uploads/2024/06/240529-E2K-ZZ-2in1-Model-_E6_AD_A3_E9_9D_A2-1600-1024x1024.jpg)
The Mixtile Zigbbee & Z-Wave Interface card is designed to provide Zigbee & Z-Wave capabilities to IoT gateways and other devices. The module has an M.2 connector and can be integrated with the Home Assistant and other similar dev platforms. The module is relatively inexpensive...
Continue Reading![Apple’s Embedded Swift Programming Language Now Supports ESP32-C6, nRF52840, RP2040 and other MCUs Apple’s Embedded Swift Programming Language Now Supports ESP32-C6, nRF52840, RP2040 and other MCUs](https://www.electronics-lab.com/wp-content/uploads/2024/06/Embedded-Swift-meets-ESP32C6-RP2040-and-more-1024x398.jpg)
Apple has recently released a beta version of Embedded Swift programming language that is said to work with ESP32-C6, Pi RP2040, STM32F7, and nRF52840 microcontrollers. Additionally, the company has also developed example codes for matter protocol based on ESP-IDF and ESP-Matter SDKs...
Continue Reading![HealthyPi Move: Open-Source Biometric Monitor in a Watch Form Factor HealthyPi Move: Open-Source Biometric Monitor in a Watch Form Factor](https://www.electronics-lab.com/wp-content/uploads/2024/06/HealthyPi-Move-1024x519.jpg)
HealthyPi Move is an open-source biometric monitor in a sleek watch form factor, designed for continuous or intermittent monitoring of vital biometric signals such as ECG, heart rate, HRV, PPG, SpO₂, blood-pressure trends, and respiration. Engineered for both everyday use and advanced...
