The MS2130 Mini, featuring the Raspberry Pi Pico 2’s HSTX interface, is an HDMI to USB 3.0 4K video capture card that supports 1080p 60fps for live streaming and recording.
FPGARaspberry Pi
The MS2130 Mini 4K Video Capture Card is a compact and high-quality device designed for capturing HDMI video and audio signals for use on computers or online streaming platforms. It supports input resolutions up to 4K@30Hz and outputs at 1080P@60fps with YUY2 full HD color depth,...
Affordable LILYGO T7-C6 Compact Development Board Featuring ESP32-C6 chip and Qwiic connector for Arduino IDE and Micropython
ArduinoIoT
LILYGO has recently showcased the T7-C6, a compact development board featuring the ESP32-C6-MINI-1 module with 4MB Flash. It supports wireless protocols like 2.4GHz Wi-Fi 6, Bluetooth 5 (LE), and IEEE 802.15.4, making it ideal for IoT applications. It is programmable in C/C++,...
M5PaperS3: 4.7-inch Touch E-Ink Display with 16-level Grayscale, GT911 Capacitive Touch, and Gyroscope Sensor
LCD/OLED/ePaper
The PaperS3 is an ESP32-S3 Development Kit designed as a low-power e-ink display controller. Powered by the ESP32-S3R8 SoC, it features a 4.7-inch e-ink display with a 960×540 resolution and 16-level grayscale. The display integrates a GT911 capacitive touch panel, enabling dual-point...
Arduino Core Beta with ZephyrOS with New Features and Changes Improved Embedded Development
Arduino
The Arduino Team launched the beta version of Arduino core with ZephyrOS last July, representing a significant milestone in its development journey. ZephyrOS is a free, real-time operating system (RTOS) designed for limited power devices and resources, offering real-time performance...
Murata Launches LBWA0ZZ2HK and LBWA0ZZ2HL Ultra-Low Power Wi-Fi HaLow 11ah Modules for Long-Range IoT Applications
IoTRFTop Stories
Murata has launched two ultra-low-power Wi-Fi HaLow 11ah modules, LBWA0ZZ2HK and LBWA0ZZ2HL. These modules comply with Sub-1 GHz (S1G) Wi-Fi standards and enable high-speed communication over distances of more than 1km. These compact modules support +23dBm (Type 2HK) and +13dBm (Type...
Toybrick TB-RK3576D SBC with Rockchip RK3576, Mali-G52, and 4K Display Support
PCBSBCTop Stories
The Toybrick TB-RK3576D is a compact Single Board Computer (SBC) designed for high-performance computing and multimedia applications. It features dual Gigabit Ethernet ports, a PCIe slot, and multiple display interfaces, making it suitable for networked systems, industrial use, and...
SECO SOM-SMARC-Genio510 and Genio700 Modules with MediaTek Genio 510 and 700 SoCs for Edge AI Applications
AIPCB
SECO has unveiled two new SMARC system-on-modules: the SOM-SMARC-Genio510 and SOM-SMARC-Genio700, powered by MediaTek Genio 510 and 700 SoCs featuring Cortex-A78 and Cortex-A55 cores. These industrial-grade modules are designed for high power efficiency, delivering reduced energy...
Pimoroni Presto Beta is An RP2350 Powered 4-Inch Touchscreen Display with RGB Backlighting and Wireless Connectivity for IoT Applications
LCD/OLED/ePaperRaspberry PiTop Stories
Pimoroni has recently launched the Presto Beta Edition, a versatile, connected desktop display companion powered by an RP2350 chip. It features a 4-inch square touchscreen with a 480x480 resolution, housed in an elegant black aluminium stand with RGB backlighting. This is designed as a...
