Elecrow Pi Terminal Review – An All-in-One 7-Inch Industrial Computer with Raspberry Pi CM4 Features LoRa, 4G, CAN Bus, Wi-Fi, BLE, and Dual GbE LAN
LCD/OLED/ePaperRaspberry PiSBC
Introduction Industrial-grade computers are evolving fast, and the Pi Terminal 7-inch Industrial Computer by Elecrow is a perfect example. It combines a 7-inch IPS display with the power of the Raspberry Pi Compute Module 4 (CM4). This compact yet feature-rich device is designed for...
OrangePi CM5: RK3588S SoC-Based Compute Module with AI, 8K Support
AISoM-CoMTop Stories
The OrangePi Compute Module 5 (CM5) is an industrial PC designed for deep-embedded applications, offering a high-performance alternative to the Raspberry Pi Compute Module 4 (CM4). Built around the Rockchip RK3588S system-on-chip (SoC), the CM5 is optimized for on-device machine...
Orange Pi 5 Ultra SBC with Rockchip RK3588 SoC, Mali-G610 GPU, and 6 TOPS NPU for 8K and Edge AI Applications
Raspberry PiSBCTop Stories
The OrangePi 5 Ultra SBC features the Rockchip RK3588 SoC, which boasts an octa-core 64-bit processor with 4 Cortex-A76 cores running at 2.4GHz and 4 Cortex-A55 cores at 1.8GHz, along with an independent NEON coprocessor. Built on an 8nm LP process, it integrates the ARM Mali-G610 GPU,...
M5Stack Module LLM: AX630C SoC with 3.2 TOPs NPU for Offline AI Applications
Arduino
M5Stack's Module LLM is an offline Large Language Model (LLM) inference module powered by the AX630C SoC, designed for terminal devices in smart homes, voice assistants, and industrial control systems. It enables local AI processing without relying on cloud services, enhancing privacy...
Nova is A RP2040-based Board with Integrated 7×10 LED Matrix for Compact Projects
LedRaspberry Pi
Nova is a compact and versatile RP2040-based board with an integrated 7x10 addressable LED matrix, designed to bring high performance and creativity to small-scale projects.  It is ideal for creating vibrant, dynamic displays with ease. With a USB Type-C port for modern connectivity...
Lanner NCA-1050: Fanless Gateway with Intel Atom X7835RE/X7405C/X7203C for Secure Edge and AI Workloads
Products
The Lanner NCA-1050 is a fanless gateway appliance designed for small and medium-sized businesses (SMBs), offering advanced network security and edge computing capabilities. It is powered by Intel Atom X7835RE, X7405C, and X7203C processors, which integrate Intel AES-NI for enhanced...
AMPCOM 9-Port 2.5GbE Switch with Web Management, 10G SFP+ uplink, and QoS for Office and Surveillance Networks
Products
The AMPCOM 2.5GbE Managed Switch is a high-performance 9-port Ethernet switch featuring 8 RJ45 ports (100/1000/2500 Mbps) and a 10G SFP+ uplink port, designed for seamless network connectivity and management. Various IEEE standards are supported by the switch, and QoS prioritization,...
Axiomtek CEM710 COM Express Module comes with Intel Xeon D-1700 10 Core CPU, 64GB ECC, and 100Gbps Ethernet support
SoM-CoM
The Axiomtek CEM710 COM Express Module is powered by Intel Xeon D-1700 Series processors, designed for edge computing, industrial automation, and data-intensive applications. The module offers up to 10 cores, up to 100Gbps Ethernet support, and 64GB of DDR4 ECC memory. Key features of...
