u-blox X20 all-band GNSS module Supports Multi-Band Signals for High-Precision Positioning
GPS
u-blox has recently released the X20 all-band GNSS module designed to provide centimeter-level accuracy in a global market. The module includes a multi-band GNSS receiver along with an L-band receiver which receives signals from L1, L2, L5, and the new L6/E6 bands. The module also...
XIAO ESP32S3 with Wio-SX1262 LoRa Module Support for Meshtastic and IoT Applications
IoT
Seeed Studio has recently released the XIAO ESP32S3 for Meshtastic and LoRa development kit that integrates the XIAO ESP32S3 board with the compact Wio-SX1262 LoRa module, connected via a board-to-board interface for seamless operation. The dual-core Xtensa ESP32S3 processor powers the...
Synaptics SYN4383 and SYN43756(E) Tri-Band SoCs are Designed for IoT Devices, Automotive, and Industrial Applications
IoTSoC-SiP
Synaptics has finally revealed the SYN4383 and the SYN43756(E) high-performance, compact tri-band SoCs, that integrate Wi-Fi, Bluetooth, and IEEE 802.15.4 radios to optimize wireless connectivity for IoT devices. Both chips support Wi-Fi 6/6E with 2x2 MIMO antenna configurations,...
StreamUnlimited Launches Stream210: A Compact, Embedded Hardware Module for Audio Streaming and IoT with Realtek Ameba RTL8730E with Low Power Consumption
AudioIoT
StreamUnlimited has recently developed in partnership with Realtek Semiconductors, the Stream210, a compact, embedded hardware module designed for audio streaming and IoT applications. This module supports Realtek Ameba RTL8730E as its core, chosen for its performance in power, size,...
Gero Mueller’s NanoTracer can monitor ultra-low currents
Test/Measurements
In industries with advanced equipment, precise and efficient voltage sources are essential, especially for applications involving nanoampere-level current measurements. One notable innovation in this area is the NanoTracer, developed by Gero Mueller and INRIA, which delivers a...
DFI RPS101/RPS103 Mini-ITX Motherboard with Intel Core and R680E/Q670E/H610E Chipsets for Automation and Kiosk Applications
SBC
The DFI RPS101/RPS103 is a Mini-ITX industrial motherboard designed specifically for automation and kiosk applications. It supports Intel Core processors from the 12th to the 14th generation, making it suitable for real-time processing in industrial environments. With a compact form...
Datanoise PicoADK v2: a DSP with Raspberry Pi RP2350A
AudioRaspberry Pi
Datanoise is a Berlin-based music hardware company, that recently released the PicoADK v2 by Datanoise, the successor to PicoADK v1 is designed for Audio Digital Signal Processing (DSP). It is a Synthesizer Development Platform used for building and experimenting with sound synthesis....
AAEON Reimagines its Flagship UP Board with the Introduction of the UP 710S
SBC
Wi-Fi support, serial communication, and a slimmer design make the UP 710S a modernized industrial board with deep ties to its origins. AAEON's UP brand , which began with the creation of the credit-card sized UP developer board almost a decade ago, has introduced the UP 710S, a...
