ASUS Tinker Board 3: Rockchip RK3566 SBC with Quad-Core Cortex-A55 and M.2 Expansion
SBCTop Stories
ASUS Tinker Board 3 is a single-board computer (SBC) powered by the Rockchip RK3566 SoC, featuring a quad-core Arm Cortex-A55 64-bit processor. It supports 4K display via HDMI and MIPI-DSI, offers gigabit Ethernet, and has four USB ports (USB 3.0 and USB 2.0). It includes an M.2 E...
Minisforum UM760 Slim: Compact Mini PC with Ryzen 5, 96GB DDR5, and 8K Display Support
SBC
Minisforum has introduced the UM760 Slim mini PC, built with the AMD Ryzen 5 7640HS processor and AMD Radeon 760M GPU for efficient performance in various computing tasks. It supports up to 96GB of DDR5 memory through dual SO-DIMM slots and includes two M.2 PCIe 4.0 SSD slots for...
Maker Go Launches Low-Cost Arduino UNO R4 Minima Clone for Under $1
Arduino
Maker Go, a Chinese hobbyist electronics specialist, has introduced a cost-effective alternative to the Arduino UNO R4 Minima, built around the same Renesas RA4M1 microcontroller. This clone significantly reduces the cost of entry, with an initial price of under $1 for a limited...
W5100S And W5500: Raspberry Pi RP2350 Based Embedded Internet Controllers for Your IoT Projects
IoTMcuRaspberry Pi
The WIZnet has recently launched two Raspberry Pi RP2350-based - W5100S-EVB-Pico2 and W5500-EVB-Pico2 Embedded Internet controllers with TCP/IP stack that simplifies Internet connectivity for embedded systems. The W5100S supports both SPI (up to 70MHz) and Parallel System Bus...
ASUS 3.5-inch SBC-Supported Intel Atom X7433RE Processor with Dual LAN, DDR5 RAM, And Multiple Display Support for Industrial and IoT Applications
IoTSBCTop Stories
ASUS has recently launched a 3.5-inch SBC (Single Board Computer) with an Intel Atom X7433RE processor, which is a compact, low-power computing solution designed for industrial and embedded applications. Powered by the Intel Amston Lake SoC, it offers efficient performance with a TDP...
Juno Tab 3: An Intel N100 Linux Based tablet with 12.1-inch 2K IPS Display and GPS Driving using Pure Maps
GPSProducts
Juno Computers has recently launched the Juno Tab 3, a versatile tablet powered by an Intel N100 Linux tablet processor (Quad-core) with a 12.1-inch 2K IPS touchscreen display (2160×1440) and 12GB of LPDDR5 RAM, making it suitable for smooth multitasking. It has a 512GB SSD for storage...
ASRock SBC-374 3.5-inch Motherboard with Intel Core Ultra Meteor Lake-PS and Xe LPG Graphics
SBC
The ASRock Industrial SBC-374 is a powerful 3.5-inch motherboard designed for embedded applications. It is equipped with an Intel Core Ultra Meteor Lake-PS processor on an LGA 1851 socket, supported by an AMI SPI BIOS with secure flash capabilities for enhanced security in demanding...
MSI MS-CF17: 3.5-inch SBC with Intel 13th Gen Raptor Lake-P for Industrial and Embedded Applications
SBC
The MSI IPC has recently released the MSI MS-CF17, a 3.5-inch SBC (Single Board Computer) Powered by Intel Raptor Lake 13th Gen processor. This provides high-performance industrial and embedded applications capable of operating in wide temperature ranges. It is designed for fanless,...
