![DC-ROMA RISC-V Laptop II with SpacemIT K1 Octa-Core SoC to Run Ubuntu Supported by Canonical DC-ROMA RISC-V Laptop II with SpacemIT K1 Octa-Core SoC to Run Ubuntu Supported by Canonical](https://www.electronics-lab.com/wp-content/uploads/2024/07/DC-ROMA-II-UBUNTU-RISC-V-Laptop-1024x777.jpg)
Deep Computing has announced the DC-ROMA RISC-V Laptop II, which is powered by a 2.0 GHz SpacemIT K1 octa-core 64-bit RISC-V processor, coupled with up to 16GB of DDR4 memory, and runs Ubuntu with official support from Canonical. In 2022, Deep Computing unveiled the first RISC-V laptop...
Continue Reading![Cervoz MEC-LAN-2631i PCIe Expansion Card is Designed to add 2.5GbE Connectivity with M.2 Port Cervoz MEC-LAN-2631i PCIe Expansion Card is Designed to add 2.5GbE Connectivity with M.2 Port](https://www.electronics-lab.com/wp-content/uploads/2024/07/New-Products-2.5GbE-M.2-Ethernet-Card-Serie_1.png)
Cervoz MEC-LAN-2631i is a PCIe Ethernet expansion card in an M.2 2230 A+E key form factor. The card is industrial grade and provides 2.5GbE Ethernet capabilities with a PCIe x1 interface. With this design, the card can provide a 2.5GbE port in case you need an additional port on your...
Continue Reading![Quartz64 Zero SBC: Featuring Rockchip RK3566T with ARM Cortex-A55 and Mali-G52 Quartz64 Zero SBC: Featuring Rockchip RK3566T with ARM Cortex-A55 and Mali-G52](https://www.electronics-lab.com/wp-content/uploads/2024/07/Quartz64-Zero-1.jpg)
Quartz64 Zero SBC from Pine64 is a small and inexpensive single-board computer. This board incorporates the Rockchip RK3566T SoC, which comprises a quad-core ARM Cortex-A55 1.6GHz CPU and a Mali-G52-2EE GPU. It can drive a single 4K display at 60fps and remains cool even when under...
Continue Reading![Windows 11 IoT Enterprise 2024 LTSC Now Available for Embedded and IoT Devices Windows 11 IoT Enterprise 2024 LTSC Now Available for Embedded and IoT Devices](https://www.electronics-lab.com/wp-content/uploads/2024/07/1663172480_win_11_iot_enterprise_ltsc_source-_xeno_twitter-1024x576.jpg)
Windows 11 IoT Enterprise 2024 LTSC is a new operating system for embedded and IoT devices. It offers enhanced features like Wi-Fi 6/7 and USB 4 support, along with advanced security and device management capabilities. Microsoft provides two update models, CBB/GAC and LTSC, for...
Continue Reading![AIC8800 Wi-Fi 6 USB Adapter 2.4GHz Wi-Fi 6 USB Adapter only costs $3 AIC8800 Wi-Fi 6 USB Adapter 2.4GHz Wi-Fi 6 USB Adapter only costs $3](https://www.electronics-lab.com/wp-content/uploads/2024/07/Tenda-W311MI-V6-vs-BrosTrend-AX5.webp)
The AIC8800 Wi-Fi 6 USB Adapter is an AX300 USB adapter based on the AIC8800 chipset, the more adept sells on Aliexpress for under $3 and can be considered one of the cheapest Wi-Fi 6 USB Adapters that can be found on the market. The adapter only supports 2.4GHz Wi-Fi and does not...
Continue Reading![SB Components StackyFi A ESP32-S3 Board in Raspberry Pi Zero From Factor SB Components StackyFi A ESP32-S3 Board in Raspberry Pi Zero From Factor](https://www.electronics-lab.com/wp-content/uploads/2024/07/6c679ea0aa4d6a1d93e4386121dcd6de_original.jpg)
SB Components StackyFi is an ESP32-S3 powered development board in a Raspberry Pi Zero Form Factor. The board features a 40-pin GPIO header which is compatible with most Raspberry Pi HAT. The board also has dual USB-C ports (one native, one for serial debugging), an IMU sensor, an RGB...
Continue Reading![High Torque Robotics Mini π – A Orange Pi 5 based Bipedal Robot with Model Predictive Control High Torque Robotics Mini π – A Orange Pi 5 based Bipedal Robot with Model Predictive Control](https://www.electronics-lab.com/wp-content/uploads/2024/07/双足机器人-Pi-1-1024x576.png)
High Torque Robotics Mini π is a 54cm tall bipedal robot built around the Orange Pi 5 SBC with Rockchip RK3588S for better performance and control. The robot has 12 degrees of freedom(DOF) with 12 custom joint motors, allowing it to walk, dance, run, jump, and flip. Designed for...
Continue Reading![Khadas Mind Graphics eGPU features NVIDIA GeForce RTX 4060 Ti Khadas Mind Graphics eGPU features NVIDIA GeForce RTX 4060 Ti](https://www.electronics-lab.com/wp-content/uploads/2024/07/8cab1f_ad30bfc9c0ca44f7b4c6bb014e828547mv2-e1721391185760.webp)
Khadas has introduced the Mind Graphics eGPU, which features the NVIDIA GeForce NVIDIA Ti. This external GPU enhances performance for creative design, video rendering, and gaming. Key features include DLSS 3 technology for smoother frame rates, AV1 encoding for better video...
