179 -
Days Won
5
admin last won the day on June 3 2020
admin had the most liked content!
About admin
Contact Methods
Website URL
http://www.electronics-lab.com
Profile Information
Gender
Male
Recent Profile Visitors
22,340 profile views
admin's Achievements
Dear Sir,
I would like your help.
I am looking for a circuit diagram with a PCB that would rotate the motor shown in the picture at 33 and 45 revolutions.
you need a quartz precision controller and a digital display that shows the real speed with the Hall sensor mounted on the motor shaft.Best Regards
Andrew
lev jeysel started following admin
admin changed their profile photo
Anyone interested in a logic probe circuits anymore ?
admin replied to Lawrence101's topic in Projects Q/A
Sure, and a few additional information as well will be perfect. -
Hi there, a well designed logic probe is always welcome by hobbyists. Could you publish a preview? -
glad to hear that it worked for you.
I've cleared the server cache, do the same to your browser and try once more, please.
Assistance with the voice changer using AP8072 IC
admin replied to Electronically curious's topic in Projects Q/A
Can you confirm that the MIC polarity is correct? Also, check that you have adjusted the potentiometers to a low setting, while set them to a high level may saturate the amplifier. -
htelec.net started following admin
oh, what a find. I still have the old website on my archive! Here is the old homepage. What did you liked most on the old website ?
ok then , use a 1.5mm^2 wire for 12V/5A source.
Wire gauge is important for the amount of current it can carry without significant heating. If you are going to pull much current from the power supply then you need thick wires, otherwise normal gauge will work.
What would you like to do ? Solder them ?
Hi, Thanks for pointing us to this. We are working to make it work like you said. For now you can see your username when logged in. We will make this site wide the following days. Best,
Today we are announcing our collaboration with SnapEDA.com, the first and leading electronics design search engine of the web, that each year, over a million hardware designers around the world use it to design electronics faster, making everything from smartwatches, to drones, and robots. They provide ready-to-use building blocks for design, including symbols & PCB footprints, their library shaves days off product development, allowing designers to focus on optimization and innovation. With a common purpose of making engineers’ lives easier, SnapEDA and Electronics-Lab have teamed up to provide their engineering community with SnapEDA’s seamless CAD search experience on Electronics-Lab.com. This new integration will allow engineers to search, discover and download millions of CAD models (symbols, footprints, and 3D models) directly from Electronics-lab.com. Engineers will also be able to find other resources like datasheets, technical specifications, and purchase options. Here are some of the key features that Electronics-Lab users will experience with the new SnapEDA integration: Search millions of electronic component models by manufacturer, orderable part number, specs, and packaging. Download the symbols and footprints in over 15 PCB design formats including Altium, KiCad, Autodesk EAGLE & Fusion360, Cadence Allegro, OrCAD, Pulsonix, DipTrace, Proteus, & more. Find component datasheets. Check prices, stock availability, and purchase components directly from major distributors’ sites including Digikey, Mouser, Arrow, Online components, RS Components, among others. Request CAD models if they’re not yet available in SnapEDA’s parts library with our InstaPart service. This new collaboration will help engineers find the components they need, by searching either by part number, manufacturer, or general keywords like ‘20 pin SMD connector’ How to Search and Download SnapEDA CAD Models from Electronics-Lab.com Go to https://www.electronics-lab.com/snapeda-cad-models/?/#/ Search for any keyword like ‘Ultrasonic MEMS’
I just removed the unnecessary part, after the useful URL. A URL like that will work: https://www.ebay.com/itm/281873849657
I fixed the URL for you! I think it's a 1.5uF / 250V capacitor the one you are looking for.
