admin
Administrators
  • Content Count
    120
  • Joined
  • Last visited
Everything posted by admin
  1. They are mostly registering as a plain user, they pass the question, automatic Spam Defense which flags the accounts with spam score and they also approve their email address which is new each time.
  2. I have now added: "How many color bands a typical resistor has?", let's see how it goes and if this guessed easily i will replace it.
  3. Yes it seems so, any idea for an electronics related question?
  4. This feature is enabled on our community but seems spammers get new way to register and post. We keep a close eye on the situation.
  5. Here is another forum topic discussing this power supply. (in Russian) http://forum.cxem.net/index.php?/topic/209045-бп-на-tl081_0-30v-0002-3а-и-его-модификации/ Translated Link: https://translate.google.com/translate?sl=auto&tl=en&u=http%3A%2F%2Fforum.cxem.net%2Findex.php%3F%2Ftopic%2F209045-бп-на-tl081_0-30v-0002-3а-и-его-модификации%2F
  6. SeeedStudio is supporting the maker with this great offer! They will assemble your PCB (5 pieces) for free. You just need to purchase the parts and place the order online. More information: https://www.seeedstudio.com/free-assembly-for-5-pcbs.html
  7. Thanks for attaching the Gerber. Could you give us more information on the rating (votlage/current) of the heating element as well as why this is needed on 3D printers?
  8. I looked around for such a charger, but seems difficult to find a suitable circuit for such high current output. Let see if someone can come up with a schematic.
  9. take a look at these 3 phase motor controllers, http://www.electronics-lab.com/project/3-phase-ac-motor-controller/ http://www.electronics-lab.com/project/inteligent-power-module-ipm-board-brushless-motors/ What kind of motor is yours?
  10. Could you provide the design files or Gerber files, otherwise this is not usefull for the members of the community.
  11. Here is the project page: http://www.electronics-lab.com/project/power-supply-brushless-motor-drivers/ This board produces 400V output to power Brushless Servo Drivers, mainly IPM Modules. It is not able to drive the motor. For this purpose you will need a driver board. We can produce this board if order quantity is > 25 pieces. If this interests you, i can quote for that. An Arduino can be used to produce the control signals for the control board.
  12. This is the basic connection of BMS charger circuit. Do you need the scheme for the charger it self maybe?
  13. This power supply is also published on an old Czech electronic magazine attached here. and here is also two nice builds of this PSU: https://translate.google.com/translate?sl=auto&tl=en&u=paja-trb.cz%2Fkonstrukce%2Fzdroj.html and here: http://diyfan.blogspot.com/2012/02/adjustable-lab-power-supply.html 0-30V 3A PSU.pdf
  14. Hi there, These capacitors are filter ones and need to be placed in various spots on the board, near voltage inputs, outputs, IC power pins and other place, so they filter the noise on the Vcc line across the board, so that's why they are many and connected on main voltage. 1n5422 diodes (Schottky diode 40V 2A) are used to protect the ICs from reverse input voltage on their Vin pins, as they allow current to flow in one direction. You can use any Schottky diode with same characteristics. Welcome to our community, Mike
  15. This is a popular ESR meter across the web and we also have a revision of it published here: http://www.electronics-lab.com/project/advanced-lc-meter/ Regarding your questions on the first message, let's see if someone who has build it can help out.
  16. Can you point us to the most interesting ESR meter you've build?
  17. Hi Peter and welcome to the community. Could you share your thoughts building this LC meter and if everything worked right from the beginning.
  18. Hi and welcome to elab community Could you post a photo or diagram of what you are trying to do?
  19. I came across 2 builds of this power supply with lot's of info on the process and tuning of it. http://diyfan.blogspot.com/2012/02/adjustable-lab-power-supply.html http://www.paulvdiyblogs.net/2015/05/tuning-030v-dc-with-03a-psu-diy-kit.html Worth checking these websites.
  20. Welcome back ELECTROMAGIX, much has changed since your post above. Feel free to share any details about this interesting charger.
  21. You have to give us more information so we will be able to help.
  22. Hi Shuhrat, We are an English speaking community here. Please post in English so anyone can understand.
  23. Excellent measurements! Thanks for sharing.
  24. Hi Tintin, You have done excellent work building this power supply and your experience is valuable for all other members. I encourage you to translate the PDF in English so anyone can benefit from it. Looking forward seeing your measurements and thoughts building this PSU.
