Kevin Weddle
1,620 -
Days Won
1
Kevin Weddle last won the day on August 12 2018
Kevin Weddle had the most liked content!
About Kevin Weddle
- Birthday 02/17/1974
Recent Profile Visitors
Kevin Weddle's Achievements
2
geoffrey05 started following Kevin Weddle
HaddyS reacted to a post in a topic: High Voltage low amperage
I think at 1Khz, the capacitor could not completely charge in one cycle. No, that's not it. You have to make the resistance higher than the impedance of the capacitor.
Something I noticed about voltage multipliers. I've never seen two equally charged capacitors reverse bias a diode. But as long as the capacitors are completely charged the diode is reverse biased.
I know there is a simpler 15V to 45V voltage multiplier than the one I posted. It might be adequate. I won't bother posting that one.
Wow this Windows 10 is great.
Thanks guys. I love to hear you.
They always conduct. No matter what. These two circuits are different. Resistors don't clamp a voltage. The voltages halve, halve, and halve again until Vp. ac.pdf
The other equation is Xc - Xl. So a series LRC is only inductive or capacitive.
In the quation v = L di/dt. The voltage goes up and the current goes up. In the equation i = C dv/dt. The voltage goes up and the current goes up.
The only addition I'll add to my post is the current of the capacitor must at least be C dv/dt.
Capacitor's pull current through a resistance. Then you have voltage momentarily.
I went ahead and built this circuit today. The input resistor voltage changed very little. The output transistor voltages changed quite a bit.
The schematic shown has a gain of 10. I changed the gain to 10,000 in this circuit. I don't know how unstable that would make it. I guess I'll have to match the opamp and output transistors.
