ryanleung
58 -
ryanleung's Achievements
What is the differences between the static power dissipation and the switching power dissipation in a CMOS inverter and what parameters that affact the switching power dissipation?
amplify the power (infrared)
ryanleung replied to ryanleung's topic in Electronic Projects Design/Ideas
Yes And I have a some question to ask you. My oscillator can not adjust the frequency to 38kHz. I use 220nF capacitor and 180uH inductor and I can not decrease the frequency anymore. -
How can i increase the transmit distance? now, it can work 6-8 inch only -
The circuit can sucessfully received the signal. If I want to add the Automatic Gain Control(AGC) to the receiver, how can I do???? -
The red circle voltage measured is not 5.9V, it is 9V same as the VCC Is it no current though the IR LEDs? -
Ok, I will try it. thanks -
how about the distance, the signal is very weak -
hello audioguru~~ I have are few question about my project. 1. I constructed your receiver already. And I amplified the signal using opamp, then it was connected to the audio amplifier. But the sound is very weak. I try to adjust the volume but the sound is also weak. I don't know how to increase the signal. And the maximum distance only have about 5cm that is very short. 2. I constructed the envelope detector (R=40ohm, C=0.1uf) and connected to your receiver output but the envelope detector output have not output signal. thanks -
The resistor is 40ohm and the capacitor is 0.1uF. The frequency is 38kHz. Is it right? f=1/(2*pi*R*C) -
should I amplify the signal again?(tansmitter and receiver) -
two resistors? the AM detector means the envelope detector? -
Hello audioguru, I constructed your transmitter and the receiver circuits already. -
hello audioguru. My AM transmitter output signal is 9.2Vp-p. And I changed the R1, R2, C and R3 to 2.7kohm, 10kohm, 0.01uF and 1Mohm. -
sorry, I don't know your mean. can you draw a circuit to me, thanks!!! -
umum...... How can I modify it now? Thanks
