ZomBiE
Members
  • Posts
    64
  • Joined
  • Last visited
About ZomBiE
  • Birthday 11/28/1980
ZomBiE's Achievements
Newbie
  1. What didn't you get? with 8 ohm speaker it works just as expected.
  2. You're on right tracks. You should start by checking wattage that laser of yours needs, 0-900 is not neccessary. but say 100-900 would do. Transformer where output voltage rises when open, 900v is target, would easily rise above 1200v and that might create an arc between windings. I used super-glue to create extra isolation when i tried such high-voltage projects for CCFL lamps that required 800-1250v operating. but wattage needed on output is most significant in this case. If you need a 100W toroid transformer, it wont work. Toroids in general doesn't have good enough isolation for this. PCB encapsulated transformers would be the best choice because those have quite good isolation voltage, about 5000v winding-winding.
  3. What's wrong with people? Now i have been repairing those good old computers because seems like anyone else can't do that here in Finland... What if those original logic IC's aren't available anymore? Always there's a substitute. Well, PLA IC's might be hard to find, but almost all the others can be found. Is there anything same-like problem anywhere else?
  4. What? Electrolysis? You mean electrolytic corrosion? No way, it always happen. You should use some good metal rods for this, like chrome-vanadium. like scrap screwdrivers. And low sense voltage, wich is amplified for desired level for your application. And i don't see any measuring circuit, that circuit is just a base for some audio peak detectors. This might be something like you are looking for, for detector i mean? http://www.electronics-lab.com/projects/sensors/027/index.html There's an idea of water level detector, uses DC and no worry of corroding because of VERY low voltage and when using durable metal rods.
  5. This topic went off, again. But i remembered this, and thought that i'd put those plans online. BUT: When i searched my archives, i found that this particular CD-ROM was damaged. >:( I built my own amp and it has worked for about 3 years now, almost 24/7. It doesn't work well on 4ohm speakers but 8ohm speakers it ROCKS. ;D I built it like i said at start of this topic: 4 channels single-ended, 2 channels when switched to bridged. It uses 4 pcs. LM3886 IC's, 2 per channel when bridged.
  6. Found one not rail-rail. http://www.national.com/pf/LM/LM675.html And another http://www.linear.com/pc/productDetail.jsp?navId=H0,C1,C1154,C1009,C1028,P1329 Single rail to rail op-amp in single package (20SO Powerpad) http://focus.ti.com/docs/prod/folders/print/opa569.html 5V supply though.
  7. For what type of use? that might help a bit.
  8. Laser tranceiver itself doesn't need any special programs. It works like an ordinary nullmodem cable. S/PDIF transmitter could be done by using only few transistors and requires no IC's. Toy laser pointers is propably the best choice for testing these projects, because those are cheap and easy to get. Main problem might be slew rates of those cheap laser diodes and other electronics within. My old toy pointer worked flawlessly (3* LR44 cells) with direct 5 volts signal.
  9. Li-ion chargers might not like parallel power, them dent to "sniff" input voltage to vary PWM cycles for proper regulation. And when theres a few PWM regulators, it may cause too much noise that will mixup error amplifiers of such chargers to undetermined state. ie. charger doesn't work like it should be.
  10. We tested similar assembly in our school, and we came into conclusion that gyroscopes are the best solution for this application. Try to study a bit of inertia navigation and you understand why.
  11. there's tons of them, by single IC or via discrete components
  12. receiving photodiodes produces all you mentioned. But transmitter lasers, you'll have to ask matsuhita or sanyo
  13. 20 meters. Yeah, small amount of hum, not disturbing though.
