MNA
204 -
Everything posted by MNA
I want a little more explanation on the time base generator and IC5 (4553) in the receiver circuit...... i think the latch should be made high at the fifth cycle of the input clock of 4017( i.e. at 1 Hz)....?? Waiting for quick reply Thanx for any help
the difference betweenthe two files is the filesize...... the one i had before doesn't have any pictures which reduced the size...... downloading such a big file which u gave is impossible for me....... if u have the above file(withoiut pictures ) then please post..... thanx
Hello everyone i have lost this file...somehow it got deleted from my hard disk..... if any of u have it then please post it.... upload it at any of the file sharing sites as i think uploading it here is not allowed(Rules)......
ok I'll check that.... Thanx
sorry but i didn't get it? No i haven't tried it yet but i think it has nothing to do with the waveform which is a result of some dc offset.... But i will make it variable because of the 1% tolerance factor.... i have checked the resistor values with the multimeter and then with those values i simulated the circuit...it is still not making such a big difference...... shouldn't the generator give 0 dc offset when the offset knob is closed/not pulled out(default)?..... why is it not giving 0 dc offset?.....
the generator's output impedance is 50 ohms..... changing the resistance values on the simulator doesn't result in those waveforms which i m getting from the output of the rectifier..... but giving a 1 V dc offset inthe simulation do result intaht waveform..... so it's infact the dc offset which is causing problems.... but why the function generator is changing the dc offset from time to time...i couldn't figure out......
Thanx AN920 and audioguru for yr suggestions.... I checked the input AC signal from the function generator. the DC offset was zero.... so i gave the input to the circuit and it still gave me the same output.... i again disconnected the input and checked the input again, it was then giving some DC offset aroung 0.7-1V..... I balanced the offset with the offset knob, then the output of the rectifier was good..... but after sometime without doing any changes to the input it again showed some DC..... so is there something wrong with the function generator since it's offset is varying from time to time?....... still the output at pin 7 will be 2 volts..... R4//(R3+R5) isn't it? Thanx
Audioguru, my calculations resulted symmetrical (see the fig).... m i doing wrong?
Hello everyone, please, see the attached figure1.... it is a full wave precision rectifier..... the opamps i m using is LM324.... all the resistors are 330 ohms .... i found it in an article..... calculations went fine but when i m checking it's output on oscilloscope,giving a 5 volt peak to peak sine wave input, the oscilloscope is displaying a waveform like figure 2.... please tell me what might be the problem? ...... Thanx for any help MNA
Thanx for the help everyone......
Please upload the datasheet of C1383 npn transistor ...... Thanx
for the convenience of other members......by saying "kaisa" , he means to say "how's that" ...... Faraz, I don't know how to make a robot but as far as i think controlling a simple robot(for the hobbyists) from a PC isn't very difficult...... I don't know who is more duffer..... me, you or the thread starter..... >:( Are you really an electronic engineer??? :o i think u are an electronic engineering student (from UET)........
sorry for a late reply...... Slackjack,have u got access to it or still waiting? I got the links which were inside this folder from another forum..... here i have attached the text file which contains all these links.... IMPORTANT!! the folder was updated ....it now contains links to more than 700 engineering books.....engineering_books_links.txt
Dead accurate 1Hz clock signal???
MNA replied to bobleny's topic in Electronic Projects Design/Ideas
u need a crystal of some frequency,then divide that frequency to suit your need......didn't u look at the project of the electronics-lab project section? ....... -
http://www.electronics-lab.com/projects/oscillators_timers/015/index.html I built a clock with 555 timer and dual decade counters......But it wasn't accurate obviously because of 555....As MP said crystal oscillator will be better.....the above project can be extended to make hrs/min/sec clock.....u will have to use gates to reset the hours section when it strikes 24....... -
moved from http://www.electronics-lab.com/forum/index.php?topic=567.0 http://www.bookwarez.org/megabook/index.html
Sorry Ante to confuse u.......Actually my grammar is worst beyond doubt but from Mark's post i got the idea that he is not asking about how to post a private message but how to post to PM ....PM stands for many words and I wanted to raise the point that maybe has misunderstood "PM" used in any of the posts here at this forum........ I m again saying I don't want to point mistakes in the language so don't think i m laughing at anyone......(And i m really disappointed that u took my post in that way :'( )...posted only for
m sorry if all of u have taken this post in a wrong way.......hope u don't mind it......
High Quality electronic sites
MNA replied to mixos's topic in Sell/Buy electronics - Job offer/requests
Thanx....and Appreciated...... Also check my last posts.....
ATTENTION: Illegal content (ebook/magazines/software) will be deleted
MNA replied to mixos's topic in Electronic Resources
I don't think like that.....As it is against rules and laws.....He might be facing legality problems......Judge by keeping yrself on his side......we all are unhappy but that's only what we can do :'( The only problem which arises here is that ARE WE ALLOWED TO SHARE LINKS TO SUCH BOOKS AND MAGAZINES THROUGH ELECTRONICS-LAB OR NOT ??? .........If yes then the books and magazines which were used to be uploaded at e-lab can be directed to rs or non-rs sites......and in this way we will still be able to share these books......... About the previous books which have been uploaded to e-lab,I don't think Ante will be happy to upload them again on other sites........ -
What about links to "illegal contents" like, Can we use rapidshare or other sites to upload such illegal contents and then provide links through e-lab?? (As Elektor magazines thread hasn't been deleted)...... Books posted by Ante were really beneficial and one of the best features of e-lab.....Anyway, legal problems can't be ignored....... -
Okay i will check it Thanx
Thanx to aProgrammer.....one of the old books (1966 ed)has been scanned and uploaded by aProgrammer......found it on the other forum..... just now discovered that he is here at elabs too..... for transporting the link,you all are welcome ;) 8) -
connect Output Qd of first to input of second.....and do the other labour as pointed out by sarma
