kachew
104 -
kachew's Achievements
12 V DC to a 220V AC Inverter AMplfier Design
kachew replied to faizanbrohi's topic in Electronic Projects Design/Ideas
hi au, how about the voltage spikes caps near the transformer? izzit the ceramic type too? -
hi, the capacitors for the voltage spikes is AC caps or Dc caps? thanks -
hi au, how do u choose, how u know what value of the resistors and capcitors for voltage spikes? the value of the capacitors and zener diode across the power supply of the ic? any formulas? thanks -
hi au, is this the configuration u meant? -
Dear Au, the ceramic disc capacitor is still there....which is parallel with the zener diode ;D ;D -
dear au, is this what u mean? across means parallel? -
hi au, the CD 4047 ic is burning at 1st it can be used for generating pulse but later when i turn off the power supply from the lab...it seems burn and i use OSC to check the waveform and there is only noise no longer have any square wave in it...the DC supply in is 12 volt but after i connected to the inverter circuit and transformer for amplification the reading on the power supply drop to 5V and the current goes high... is this is the modification u meant? -
dear AU , yup i know...but the osc result doesnt have the required result....i tried many times....at last i will get the same square wave form....but this is ok... the main things is the ic burn many times....although i have use diff grounding and bigger size wire....can u recommend me a regulator which suit to the ic? i think this is the most efficient way....can i voltage regulator to regulate current? as i know regulator is to regulate voltage only -
dear au, ooo can u recommend me a voltage regulator? regulate to the ic.....so that the ic will be protected from being burn....thanks -
dear au, yes i have separated the ic wires to the battery connection and the heavy wires from mosfet to the ground and the to battery....but the problem is the ic need to be connected to the mosfet which acts as a wave generator to switch on and off for the mosfet....then ground of the mosfet also separated from the ic ground but the drain of the mosfet are using pcb to heavy wires then to transformer... i will take attach the pic along for you to see.....and 1 more prob which could not be solved...whcih the the waveform....i still cant get the desired waveform from cd 4001 and cd 4047.... i tried the cd 4047 output pin osc, pin Q and pin Q' all is the same in the datasheet...bt when connected to the cd 4001 it will become a square wave....which each of the output from the cd 4001 will have a phase different only not inverted waveform....when add together it will superimpose but not generating modified sine wave..... :'( :'( :'( at 1st, can generated the desired current and voltage but after awhile it will burn the CD4047 ic ...need help thanks -
dear au, about the grounding...can i separate the grounding as showed in the schematic.... i mean the mosfets has its own grounding and the ic's has it own groundin....or both mosfet and ic need to hav same grounding...i means is connected to same ground...just wan to confirm b4 i burns everything out... ;D ;D -
dear au, do i still need to add on the series resistor to the mosfet? or shouldnt i? thanks...if yes then i need to drill holes on my pcb board go lab to retry thanks -
dear Au, if the voltage from the mosfet is lower than the primary winding of the transformer for example....the voltage from the mosfet is approximately 5V then the rating of the transformer is 8V....will it have enough power to power the transformer? or it depends on the rating of the mosfet? can i put different grounding where the mosfets have different ground than ground together with the ic? becoz i afraid that the high current drain from the mosfet will affect the ic and burn it.... :-\ :-\ thanks for your precious opinion -
dear au, i have use the same connection which the updated by you...but still no avail, but i tried the cd4047 output from both pin 11, and and 10 and the output is inverted...but when fed into the CD4001...the output seems to be havin a square wave....how could this possible ? i still cant figure it what is wrong with the circuit....mayb is the frequency prob? and i also have taken out the resistor since is not needed.....and can i use the ceramic capacitor which has value of 221k? thanks for your reply -
dear au, then the 2 capacitors to be used is metalized plastic type? since there are no 0.22uF capacitors in the circuit. so 50Hz of frequency doesnt neccessary to put the resistor in front of the mosfet? since the osc frequency in this circuit is just 50Hz.... the capacitors and resistors used in the circuit is just a protection from the current of the transformer or just use for filtering purposes?
