38 -
About masterleous
- Birthday 08/09/1982
masterleous's Achievements
[Needed]: 40816229 IC Datasheet
masterleous replied to masterleous's topic in Datasheet/Parts requests
Thanks Hotwaterwizard.............alot for the datasheet and other information related to this IC.......... -
Hi all, i need some help, i will be very greatfull to you, one of my nephiew has a remote control toy car, which is operated at 27MHz frequency, (and ofcourse it is MADE IN CHINA) Inside the Remote Control a few components are their, 3X S9018 Transistors Few Resistors, Inductors, Capacitors................ and of course their is one IC (14 pin), The printed numbers on In are TX-2 40816229 I try to search about this IC, at first i thought it is a CMOS IC of CD4081.......but found me wrong........... as CD4081 - pin 14 is VCC and pin 7 is Ground........ And at this IC (mentioned above) has -ve supply connection of Battery at pin 14....... I am so much confused about this IC, if anyone knows about it, having datasheet of it................ Thanks, masterleous
Help me in Building a UPS
masterleous replied to masterleous's topic in Electronic Projects Design/Ideas
No reply from any user............ :'(................... -
Hello all users, I need some help in my project of UPS, i found some basic conecpt of UPS on NET, which is basically a 12 volts to 220/120 VAC Inverters, these types of circuits have a big problem with them, when a battery is fully charged, UPS give 220 VAC, after some time when Battery goes to its 50%, than UPS give 180-190 VAC, and when battery goes to it minimum, UPS give less than 160 VAC. So UPS is only efficient when battery is fully charged. I found some ideas from net of UPS continuously giving 220 VAC till battery goes to 30-40%, but not find any circuit of that type of UPS. Any circuit idea/schematic.......... Thanks, masterleous
Hello Guys, I need some help in using ULN2003A Darlington Pair Array IC in my project, let me explain little about my project. I want ULN2003A IC to drive 6VDC Relays, and my logic inputs are CMOS, here the input for ULN ic is coming from BCD-7 Segment IC 4511, and the output of ULN2003 is connected with 7 Relays, The relay's Normally Open Contact is used to drive 200V Circuitry. Please help me what is going wrong.......... Any new idea will be helpfull for me. Thanks
Want to make Auto Range Power Supply.
Thanks all for your replies, but i need some more help about switch mode power supplies. -
I know that many electronic devices have auto range power supply. But, i want to make my own Power supply, just like a project of 0-30V Variable Power Supply in This site. Can anyone know about it. Thanks -
masterleous posted a topic in Electronic Projects Design/Ideas
Hi all, I want to make my Auto Range Power Supply like Input : 85 - 250 VAC Output : any DC Voltage like 12VDC 2-3A Can anyone have have an idea about this.? Thanks -
Want Datasheet of Large 7 Segment LED Display
masterleous posted a topic in Datasheet/Parts requests
Hi, Want Datasheet of Large 7 Segment LED Display. The 7 segment ms t be of large size upto 10 to 12 inches.. Can any one have the information about it's power consumption with specification. -
How do I start off for a Robot
masterleous replied to Sumit Saraogi's topic in Electronic Projects Design/Ideas
Hi Kevin, you are right that it is difficult to program through Assembly Language...........but for complete automation u needed a design that perform an operation for control by its own calculation not by HMI............... Although for beginner, this is a better idea to make C Prog at first than switch to Automation through MicroProcessor or Microcontroller which is depend on user and it's robot application....... -
Help: I want to build my own Intercom.
Here is the Pic of PreAmplifier........ -
Want to use LED Dot Matrix Board
Hi, Yes u are right........ I want some help to drive LEDs.............can anyone have any idea........ I think the minimum frequency for driving it should be greater than 5-10 K Hz...........am i Right? -
