FH16
26 -
About FH16
- Birthday 02/11/1973
FH16's Achievements
export as image (monochrome)in a large resolution (300 and up), open it in photoshop, then go to image -> Ajustments -> Invert or press ctrl+I
some info's to create the 3d file ok create from eagle a povray file in a new folder e.g. temp. then make mod's to file and create the ini . copy files from ..\eagle3d\povray to \temp folder. The exported file from eagle and the ini file must have the same name e.g. test.pov test.ini, load both files to povray, be sure examples from povray are closed, render file, then use an animation program (e.g. gifcunstractor) to create animation. don't use a big number of pictures, final_frame = 500 is to big, try 100 or 200 pic's have a nice summer :)
After the creation of POV Ray file from Eagle, open it and find and replase the following: --- Find --- //Animation #declare global_anim = off; --- Replace --- //Animation #declare global_anim = on; --- Find --- #if(global_anim=on) camera { location global_anim_spline_cam_flight(clock) #if(global_anim_npoints_cam_view>2) look_at global_anim_spline_cam_view(clock) #else look_at global_anim_spline_cam_flight(clock+0.01)-<0,-0.01,0> #end angle 45 } light_source { global_anim_spline_cam_flight(clock) color rgb <1,1,1> spotlight point_at #if(global_anim_npoints_cam_view>2) global_anim_spline_cam_view(clock) #else global_anim_spline_cam_flight(clock+0.01)-<0,-0.01,0> #end radius 35 falloff 40 } #else camera { location <cam_x,cam_y,cam_z> look_at <cam_look_x,cam_look_y,cam_look_z> angle cam_a //translates the camera that <0,0,0> is over the Eagle <0,0> //translate<-48.730000,0,-21.585000> } #end --- Replace --- #if(global_anim=on) camera { angle 45 location <100.0 , 100.0 ,10.0> right x*image_width/image_height look_at <0 , 0, 0> rotate <0,-360*(clock+0.10),0> } light_source { <0,0,0> color rgb <1,1,1> } } #else camera { location <cam_x,cam_y,cam_z> look_at <cam_look_x,cam_look_y,cam_look_z> angle cam_a //translates the camera that <0,0,0> is over the Eagle <0,0> //translate<-48.730000,0,-21.585000> } #end Then Create .ini file and add the following: --- Add --- Initial_Frame = 1 Final_Frame = 500 Initial_Clock = 0 Final_Clock = 0.9 Cyclic_Animation=on [80x80 Low Resolution] Width=80 Height=80 Antialias=off Antialias_Threshold=0 [100x100 Low Resolution] Width=100 Height=100 Antialias=off Antialias_Threshold=0 [640x640 Low Resolution] Width=640 Height=640 Antialias=Off Antialias_Threshold=0 [800x600 Low Resolution] Width=640 Height=640 Antialias=Off Antialias_Threshold=0 [1024x768 Low Resolution] Width=1024 Height=768 Antialias=Off Antialias_Threshold=0 [640x640 High Resolution] Width=640 Height=640 Antialias=On Antialias_Threshold=0.5 [800x600 High Resolution] Width=800 Height=600 Antialias=On Antialias_Threshold=0.5 [1024x768 High Resolution] Width=1024 Height=768 Antialias=On Antialias_Threshold=0.5 [640x640 Very high resolution] Width=640 Height=640 Antialias=On Antialias_Threshold=1.0 [800x600 Very high resolution] Width=800 Height=600 Antialias=On Antialias_Threshold=1.0 [1024x768 Very high resolution] Width=1024 Height=768 Antialias=On Antialias_Threshold=1.0 Save file and exit (Final_Frame = 500 is the numbers of frames) Press from Pov Ray the INI button and select your ini, press button "Set but don't render" Select the resolution you want and press "RUN". Thats all :)
I'm Using Library: switch-omron Device: 10-XX Pacage: B3F-10XX
Some examples from my projects. >>>>Animation <<<<
Matthias Weiber has write a ulp for Eagle to convert PCB's in 3D images or animation. The ulp create a POV Ray file that can be used in program to create images and animation for your project. You can download the ulp from Matthias Weiber website http://www.matwei.de/doku.php?id=en:home and POVRay from from the official site www.povray.org for free. Samples from Eagle 3D
Hi, I have mate a small modification into this project. 1. Keys are added to display 2. Magnetic switch added between 12V and relay. zip file includes word file in Greek language. PCB and Silkscreen. Special tnx to Vasilis Papanikolaou for this project. DarkRoomTimerModify.zip
Here is the print and page setup dialog
The best way to print your PCB is to printed directly on an transparency or in a PDF file for batch working ;)
Hi spike0. First you must know how many cell's is your battery, then you need information from the manufacture as audioguru say allready, then try to search the net for how to build the charger (My opinion is to use a circuit with microcontroler and battery monitor IC's) and finally you must try again again you charger. Here it is an article for NiCd and NiMH batteries charger. http://www.electronics-lab.com/projects/power/037/index.html
A Channel open #Electronics-lab , use server srv.irc.gr to connect.
hey Ante, have you aver try to use a pentium 3 500MHz and stend up a firewall, proxy, mail, web, dhcp, dns, ftp and other services with windows? if yes how it works? (Deadly slow) and you Alun how many hours have spent antil all this works fine? So any software have advandage and disadvandage
Thank you sec, but I just want to use an old ATX PSU as standart stabilized psu with an lcd (or led display) for reading the voltage's from the psu. I can connect an lcd on the pic, i can take the voltage's from the psu but I can't write the code, i m not good programmer and i need help for it. Thanks again and sorry for my bad English once more.
Here it is the simplified way to turn on an ATX PSU, If you jumper the pin13 and pin 14 the PSU will turn on. For this purpose I use an MCU from Microchip the famous PIC16F84A (PIC16F84A-04/P). The schematic JP2 = Pin9 from PSU JP3 = Pin7 form PSU JP4 = Pin14 from PSU The Source Code '**************************************************************** '* Name : atxpsu.BAS * '* Author : vilias Iliadis Ilias * '* Notice : Copyright © 2004 vilias * '* : All Rights Reserved * '* Date : 16/12/2004 * '* Version : 1.0 * '* Notes : for any uptade please e-mail me [email protected] * '* : * '**************************************************************** temp var byte b2 var byte b2=0 trisa = 0 trisb = 1 porta.0 = 1 porta.1 = 0 porta.2 = 0 main: BUTTON PORTB.1,1,0,0,B2,1,pressed goto main pressed: temp = porta.0 porta.0 = porta.1 porta.1 = temp porta.2 = porta.1 goto main The question Now I
Demagnetise - Degauss component identification
FH16 replied to mixos's topic in Electronics chit chat
This device is Degaussing of picture tubes and you will find it in all crt monitor's and tv's If this component is damage when power on the main switch your device will not demagnitize your screen. For more info see http://www.epcos.com/excelon/servlet/excelon/produkt_katalog/xml/portal.xml?xslsheet=produkt_katalog:/xsl/datenblaetter.xsl&lang=e&gr=CC&prgr=PG_T_PTC_APP1
