4 -
Enrico's Achievements
PCB Etching Tank - Do it yourself
Enrico replied to billy's topic in Mechanical constructions/Hardware
I've built one too. But since i discovered Hydrogen Peroxide + Muriatic Acid, i just don't use it anymore. You can find (at least here in italy) Hydrogen Peroxide 40% vol from airdressers, it is present in the products they use to make air shiny blonde. I just lay the pcb in the plastic box and cover it with a small amount of muriatic acid (just enough to cover the pcb), then i squirt a small amount of air product and wait around 10 minutes, less if you give it a little shake sometimes. I agree that this solution is far more dangerous than using ferric cloride, but if the right precautions are taken, you save a lot of money: - No pcb tank nedeed, just a little plastic box (the mixture i mentioned above is very powerful in very little quantity) - 10 minutes maximum etching time, even for large pcbs, i had perfect results in less than 10 minutes without eating nor shaking. -
The correct place to insert a temperature sensor?
Enrico replied to Enrico's topic in Mechanical constructions/Hardware
Thank you ;) -
During the process of building my own dual-variable power supply, I decided to mount a cooling fan, controlled by a lm35 temperature sensor, to cool off the heat produced by the numerous of components. Inside my box (old ammo case from WW2) there is very little space: - 2 backlit displays (2x16 char) - 1 Toroidal transformer 50 VA - 1 Toroidal transformer 225 VA - A total of 4 "TO220" voltage regulators (2x 7805, 1x 7905, 1x 7812) each one with it's fellow heatsink. - A big heatsink where 2 LM338TK (TO3) are mounted, this heatsink is mounted partly inside the case, partly outside. I placed a 120 mm cooling fan driven by a PIC - LM35 based system. My question is: Where is the correct and most efficient place to put the LM35 sensor? I thought about the big heatsink, but it will be tiepid most of the time, because of its size and the fact that it is, in part, outside the case. I thought about the 220 VA Toroidal transformer, it should produce some heat under load. I even noticed that the various LM7xx that populates my utility pcbs are often very warm (especially the lm7805 that powers the two displays, 3 pic and some leds). I couldn't give myself a satisfying answer
