3 -
About BOsborne
- Birthday 03/30/1961
Profile Information
Gender
Male
Location
Cincinnati, OH
Recent Profile Visitors
1,862 profile views
BOsborne's Achievements
htelec.net started following BOsborne
Those are connector pins, for Canon or Deutsch.
Just a small sample of components that I have collected over the years. Unlike most sellers at Ebay, I don't try to make money from shipping. I will send by the lowest cost and not charge for packaging. I get free packaging from my work place from our shipping department, so I recycle our received items packages. I am here to help fellow electronics enthusiasts like myself. I have several of each of these. You can find the Data Sheets for them here: http://www.datasheetarchive.com/ uA715HC high speed op amp uA733HMQB Differential Video Amplifier op amp MC14011BAL Motorola 2-Input NAND-Function Logic Gate 9601DMQB Retriggerable One Shot DM7430N 8-Input NAND Gate MC6802 Microprocessor with clock and optional RAM MC10105L Triple 2-3-2-Input OR/NOR Gate MC10125L Quad MECL to TTL Transistor MC10131L Dual Type D Master-Slave Flip-Flop MC14050 HEX Buffer 7430N 8-Input NAND-Function Logic Gate 10524 Quad Ttl-to-mecl Translator 54165DMQB 8-Bit Parallel-to-Serial Converter 9601DC Retriggerable Monostable Multivibrator AM27S21DC 1,024-Bit (256 x 4) Bipolar PROM DATA SHEET: http://www.datasheetarchive.com/pdf-datasheets/Datasheets-115/DSAP00731.html ICL7109CPL Maxim Integrated Products 12 Bit A/D Converter With 3-State Binary Outputs DATA SHEET: http://www.datasheetarchive.com/pdf-datasheets/Datasheets-18/DSA-346047.html CA3028B/3 RCA General Purpose Differential Amplifier - high rel. S68B21P American Microsystems Peripheral Interface Adapter (PIA) - Peripheral I/F Adapter SN54155J Texas Instruments Dual 2 Line to 4 line Decoders/Demultiplexers SNJ54S02J Texas Instruments QUADRUPLE 2-INPUT POSITIVE-NOR GATES MC6840P Motorola Semiconductor Programmable timer module, 1 MHz SN74LS86N Motorola / Freescale Semiconductor QUAD 2-INPUT EXCLUSIVE OR GATE 2N3823 Motorola N-CHANNEL JUNCTION FIELD EFFECT TRANSISTOR 4 pins JAN2N1613 Microsemi Corporation NPN Transistor 2N2369A Texas Instruments SMALL SIGNAL NPN TRANSISTOR TO-18 2N2484 Fairchild Semiconductor NPN low level low noise amplifier. 93L425PC Fairchild General-Purpose Static RAM - Includes separate CE, WE cntrl D2148H Intel General-Purpose Static RAM - Icc 150mA max RM4156DC Raytheon Electronics Quad General Purpose Op Amp - Compensated TRW52602 TRW RF power transistor 2GHz QTY. (2) http://www.advancedsemiconductor.com/pdf/mln2033f.pdf MC14046B Motorola Phase Locked Loop ICM7218AIJI Intersil Corporation 8-Digit LED Microprocessor-Compatible Multiplexed Display Decoder Driver.... QTY. (1) DS8830N National Semiconductor Dual Differential Line Driver LF347BN National Semiconductor Wide Bandwidth Quad JFET Input Operational Amplifier LM324AN Motorola Operational Amplifier, General purpose, Quad channel, 32V, DIP, 14-Pin CA3028A RCA Differential/Cascode Amplifiers from DC to 120MHz LM311N ST Microelectronics Comparator, Single channel, Open drain/collector, 36V, DIP, 8-pin (QTY. 2) I have a plethora of other components that I will post also. I'm looking for a TDA7000 FM Receiver IC. Trimmer caps 2-45 pf range Hi frequency power transistors electret condenser microphones 330pf ceramic caps
