mc Cyber
Members
  • Content Count
    8
  • Joined
  • Last visited
  1. Voy a dar muchos datos por si alguien nos puede ayudar: Procesador OMEGA ST i5518 BVC flash 29lv800ta Sintonizador SHARP F7VZ0184 chip STV 022998 (STV 0299) Otros chip´s : STV6400 IS42 S 164000-7T Software: Suresoft Systems PVTS Fabricante Software: Highgate Decos iguales al Access: Pacific DSR 2882 Infosat DSR 9100 Decos compatibles (aparentemente) Zodiac DZR-760 CI; DZR 8310 ( fichero .urt) Televes, 7296 ( fichero .bin) Asahi, 20100 @sat, CI6100 Baff, DYB 3500 FTA ( fichero .urt) Boca DSR 204 , DSL 212 ,.. 214, .. 216, .. 218 Comag FTA 35,.. 45, ..309,.. 310, DGI 500 OTA, Silvercrest SL 65 (muy parecido los componentes) ( fichero .urt) Interstar, DSR 9002 PACIFIC DSR 2800 Vestel, -> todos ( fichero .urt) NeotionBOX NB 501,..601 Dyna, Cs 5500 Si alguien dispone de alguno de estos florecido que nos lo haga saber Espero ayudar en la busqueda
  2. I have found this and think that it is the only way to patch metronic accessbox, I'm not able to use this but any people knows how to programmer. ON WIDOWS XP: GET TO START>ALLPROGRAMS>ACCESSORIES>COMUNICATIONS>HYPER TERMINAL -INSERT A NAME AND SELECT AN ICON AND COM1 > PRESS OK -SET BIT TO 115200 -PARITY=NEVER -HARDWARE CONTROL=NEVER > PRESS OK CONNECT METRONIC ACCESSBOX TO COM1 WITH NULL MODEM CABLE AND TURN ON(STANDBY=RED LED) WAIT ANY SECONDS YOU CAN SEE ANY STRINGS ON HYPERTERMINAL WHEN THE STRINGS ARE FINISHED PRESS ENTER.YOU ENTER IN TESTTOOL MODE. WRITE HELP TO SEE ALL COMMANDS: Testtool> HELP
  3. I LOOK FOR ANY FILES COMPATIBILE WITH ACCESSBOX.
  4. no, I hope that anyone help me. you can find sti5518.zip on internet.
  5. THIS IS THE PICTURES OF MY RECEIVER METRONIC ACCESSBOX FTA. I FIND A SOFT FOR FIX IT. PLEASE HELP ME. THANK YOU
  6. HI guys, I've a receiver FTA Accessbox by metronic, It's = at another receivers with sti 5518. this is the data of receiver with winupoad 4.0 by null modem cable rs232: DebugPort initialised to 115200, 8, N, 1 Failed to sense hot keys for the second time ... O[0] N[0] No download demanded Verify CRC => Part #01. START [7FF70000] Size[505644] CRC[D15812AB] Ver[ 13 ] Terminating system services.. UnCompressed Image Size => [ 0x7FF50008 ] Bytes Decompress Start => [ 0xC0783000 ] Image Decompressed successfully... Image StartAddress => [ 0x7FF70000 ] UnCompressed Image Size => [ 0x7FF70008 ] Bytes Decompress Start => [ 0xC0080000 ] Preparing to start application.. BOOT ADDRESS => [ 0xC0192FBE ] STAVMEM_Init()=Ok STAVMEM_CreatePartition()=Ok STEVT_Init()=Ok STPWM_Init()=Ok STI2C_Init(back)=Ok STI2C_Init(front)=Ok PTI interrupt level 6 src\pti\ptiinit.c 405> Suceesfully enabled the PTI interrupt PTI_Init()=Ok STCLKRV_Init(CLKRV2)=Ok STCLKRV_Open(CLKRV2)=Ok STAUD_Init(AUD0)=Ok STDENC_Init(DENC0, InvOut 1)=Ok STVTG_Init(VTG0)=Ok STVID_Init(VID0)=Ok STE2P_Init(EEPROM) Size[2048]=Ok initterm.c, 1552 Info> Report module is initialised ... flashdrv.c 1908> Flash Driver Init OK main.c 352> Lnb [8] Sat [28] Car [40] Ser [32]memdata.c 307> Eeprom End Offset [512] memdata.c 332> eDBE Box Info Size [28] memdata.c 363> User Box Info Size [52] memdata.c 394> Wakeup timer Info Size [224] ***************************** MPEG - ModuleInfo ***************************** Platform Id - STi5518 Toolset Used - DCU 1.8.1 Compiled On - Jan 28 2003 at 15:21:24 MPEG Module Version - Ver 1.3.14 Rev.0 *************************************************************************** VIDEO Matrix initialisation stv6400.c 799> successfully created video matrix process HWC_AVMATRIX_InitModule()= OK vpwmctrl.c 215> Install PWM interrupt 11 at level 1 Res Start Address = C0783000 Res Data - 544F4F52 4F4C425F 00004B43 C0081238 ========================================================== || || || eGOS Version 2.2.33.0 || || || || PLATFORMID 551x Date Apr 21 2003 Time 11:55:17 || || || ========================================================== main.c 1118> Success in creating Common User interface main.c 573> RF => CH No. [35], O/P Mode [1] Summary of SDB:- ============================================== Name BlkStart PLStart #Records ============================================== Lnb C07EAE70 C07EAE80 7 Satelli C07EAED4 C07EAEE4 10 Carrier C07EAFFC C07EB00C 136 Service C07EC32C C07EC33C 406 ============================================== _-_-_-_-_ eIRRXVer3.1.0.0 May 31 2003 14:57:20 _-_-_-_-_ mmi.c 260> Success in creating IR Receiver Thread fpkeys.c 424> FPKeyBoard Thread created @[6] with StkSize[3072] ######## AFTER MMI CREATE() Major[2] Minor[2] Build[33] Platform[551x]Toolset[DCU Version] Date[n] Name[3] ============================================== Version of May 31 2003 at 14:49:20 Built for Chip STi5518 in board CPU Clock Speed = 81000000 ============================================== System initialised - hit return to enter testtool Heap Remaining : Start[C03D53EC] End[C03FDBEC] Size[162 Kb] Heap Remaining In SYSTEM PARTITION: Start[C01D011C] End[C030591C] Size[1267712] main.c 754> Lnb [8] Sat [28] Car [40] Ser [32] ==================================== = eDEMOD1.0-STV0299 Build R1.1.9May 31 2003 14:58:43 = ==================================== hwc0299.c 4125> TUNER (STV0299) Module Initialisation Creating TUNER module semaphores ... LNB Power Control by CPU PIO[2000C000] [20]... LNB Polarisation Control by CPU PIO[2000C000] [40]... Selecting Tuner ... Type[0D] Addr[C0] nsfilter.c 3400> SECTION FILTER Driver version[HWC_SFILTER_55xx/3.0 May 31 2003 14:59:31.] nsfilter.c 3419> Successfully intialised the Circular buffer Manager ... nsfilter.c 3552> Creating SFILTER MONITOR Process @[9] WS[9216] NO_OF_SIMULTANEOUS_FILTERS => 32 FILTER_DEPTH_SIZE => 14 MAXIMUM_NO_OF_STREAMS => 32 nsfilter.c 3633> Succesfully Installed SFILTER module ============================================ NDB Ver 1.7.4 built on May 31 2003 15:00:42 NAVDVB Ver 1.2.6 BUILDER Ver 1.2.9 STORAGE Ver 1.2.2 MEMORY Ver 1.2.2 DEBUG Ver 1.0.3 ============================================ ndbfcm.c 4366> Database successfully initialised irdmon.c 449> Creating IRD @(5) WS[3072] irdmon.c 499> IRDMON successfully created navdvbif.c 379> Initialising Teletext... ********************************************************** eTTXT - 4.4.0T3 27/05/2003 ********************************************************** Started Initialising... Successfully Initialized Teletext Driver. navdvbif.c 385> Opening VBIAppl ... navdvbif.c 441> Initialised Audio WatchDog module ... watchdog.c 697> Created the WD_Thread @12 Stk[4096] navdvbif.c 457> Initialised HW watchdog module ... dvbmmi.c 635> Successfully created TIMER_Thread *********************************************** is there a compatible path for this receiver? thank you!! PLEASE UPLOAD!!
  7. HI guys, I've a receiver FTA Accessbox by metronic, It's = at another receivers with sti 5518. this is the data of receiver with winupoad 4.0 by null modem cable rs232: DebugPort initialised to 115200, 8, N, 1 Failed to sense hot keys for the second time ... O[0] N[0] No download demanded Verify CRC => Part #01. START [7FF70000] Size[505644] CRC[D15812AB] Ver[ 13 ] Terminating system services.. UnCompressed Image Size => [ 0x7FF50008 ] Bytes Decompress Start => [ 0xC0783000 ] Image Decompressed successfully... Image StartAddress => [ 0x7FF70000 ] UnCompressed Image Size => [ 0x7FF70008 ] Bytes Decompress Start => [ 0xC0080000 ] Preparing to start application.. BOOT ADDRESS => [ 0xC0192FBE ] STAVMEM_Init()=Ok STAVMEM_CreatePartition()=Ok STEVT_Init()=Ok STPWM_Init()=Ok STI2C_Init(back)=Ok STI2C_Init(front)=Ok PTI interrupt level 6 src\pti\ptiinit.c 405> Suceesfully enabled the PTI interrupt PTI_Init()=Ok STCLKRV_Init(CLKRV2)=Ok STCLKRV_Open(CLKRV2)=Ok STAUD_Init(AUD0)=Ok STDENC_Init(DENC0, InvOut 1)=Ok STVTG_Init(VTG0)=Ok STVID_Init(VID0)=Ok STE2P_Init(EEPROM) Size[2048]=Ok initterm.c, 1552 Info> Report module is initialised ... flashdrv.c 1908> Flash Driver Init OK main.c 352> Lnb [8] Sat [28] Car [40] Ser [32]memdata.c 307> Eeprom End Offset [512] memdata.c 332> eDBE Box Info Size [28] memdata.c 363> User Box Info Size [52] memdata.c 394> Wakeup timer Info Size [224] ***************************** MPEG - ModuleInfo ***************************** Platform Id - STi5518 Toolset Used - DCU 1.8.1 Compiled On - Jan 28 2003 at 15:21:24 MPEG Module Version - Ver 1.3.14 Rev.0 *************************************************************************** VIDEO Matrix initialisation stv6400.c 799> successfully created video matrix process HWC_AVMATRIX_InitModule()= OK vpwmctrl.c 215> Install PWM interrupt 11 at level 1 Res Start Address = C0783000 Res Data - 544F4F52 4F4C425F 00004B43 C0081238 ========================================================== || || || eGOS Version 2.2.33.0 || || || || PLATFORMID 551x Date Apr 21 2003 Time 11:55:17 || || || ========================================================== main.c 1118> Success in creating Common User interface main.c 573> RF => CH No. [35], O/P Mode [1] Summary of SDB:- ============================================== Name BlkStart PLStart #Records ============================================== Lnb C07EAE70 C07EAE80 7 Satelli C07EAED4 C07EAEE4 10 Carrier C07EAFFC C07EB00C 136 Service C07EC32C C07EC33C 406 ============================================== _-_-_-_-_ eIRRXVer3.1.0.0 May 31 2003 14:57:20 _-_-_-_-_ mmi.c 260> Success in creating IR Receiver Thread fpkeys.c 424> FPKeyBoard Thread created @[6] with StkSize[3072] ######## AFTER MMI CREATE() Major[2] Minor[2] Build[33] Platform[551x]Toolset[DCU Version] Date[n] Name[3] ============================================== Version of May 31 2003 at 14:49:20 Built for Chip STi5518 in board CPU Clock Speed = 81000000 ============================================== System initialised - hit return to enter testtool Heap Remaining : Start[C03D53EC] End[C03FDBEC] Size[162 Kb] Heap Remaining In SYSTEM PARTITION: Start[C01D011C] End[C030591C] Size[1267712] main.c 754> Lnb [8] Sat [28] Car [40] Ser [32] ==================================== = eDEMOD1.0-STV0299 Build R1.1.9May 31 2003 14:58:43 = ==================================== hwc0299.c 4125> TUNER (STV0299) Module Initialisation Creating TUNER module semaphores ... LNB Power Control by CPU PIO[2000C000] [20]... LNB Polarisation Control by CPU PIO[2000C000] [40]... Selecting Tuner ... Type[0D] Addr[C0] nsfilter.c 3400> SECTION FILTER Driver version[HWC_SFILTER_55xx/3.0 May 31 2003 14:59:31.] nsfilter.c 3419> Successfully intialised the Circular buffer Manager ... nsfilter.c 3552> Creating SFILTER MONITOR Process @[9] WS[9216] NO_OF_SIMULTANEOUS_FILTERS => 32 FILTER_DEPTH_SIZE => 14 MAXIMUM_NO_OF_STREAMS => 32 nsfilter.c 3633> Succesfully Installed SFILTER module ============================================ NDB Ver 1.7.4 built on May 31 2003 15:00:42 NAVDVB Ver 1.2.6 BUILDER Ver 1.2.9 STORAGE Ver 1.2.2 MEMORY Ver 1.2.2 DEBUG Ver 1.0.3 ============================================ ndbfcm.c 4366> Database successfully initialised irdmon.c 449> Creating IRD @(5) WS[3072] irdmon.c 499> IRDMON successfully created navdvbif.c 379> Initialising Teletext... ********************************************************** eTTXT - 4.4.0T3 27/05/2003 ********************************************************** Started Initialising... Successfully Initialized Teletext Driver. navdvbif.c 385> Opening VBIAppl ... navdvbif.c 441> Initialised Audio WatchDog module ... watchdog.c 697> Created the WD_Thread @12 Stk[4096] navdvbif.c 457> Initialised HW watchdog module ... dvbmmi.c 635> Successfully created TIMER_Thread *********************************************** is there a compatible path for this receiver? thank you!! PLEASE UPLOAD!!
