Davaliao
Members
  • Posts
    4
  • Joined
  • Last visited
Davaliao's Achievements
Newbie
  1. The Micron Imaging MT9V011 is a VGA-format with a 1/4-inch CMOS active-pixel digital image sensor. The active imaging pixel array is 649H x 489V. It incorporates sophisticated camera functions on-chip such as windowing, column and row mirroring. It is programmable through a simple two-wire serial bus interface and has very low power consumption. The MT9V011 features DigitalClarity, our breakthrough, low-noise CMOS imaging technology that achieves CCD image quality (based on signal-to-noise ratio and low-light sensitivity) while maintaining the inherent size, cost and integration advantages of CMOS. The sensor can be operated in its default mode or programmed by the user for frame size, exposure, gain setting, and other parameters. The default mode outputs a VGA-size image at 30 frames per second (fps). An on-chip analog-to-digital converter (ADC) provides 10 bits per pixel. FRAME_VALID and LINE_VALID signals are output on dedicated pins, along with a pixel clock which is synchronous with valid data. Features DigitalClarity CMOS Imaging Technology Ultra low-power, low cost CMOS image sensor Superior low-light performance Simple two-wire serial interface Auto black level calibration Window Size: VGA, programmable to any smaller format (QVGA, CIF) Programmable Controls: Gain, frame rate, left-right and up-down image reversal, window size and panning Applications Cellular phones PDAs PC Cameras Toys and other battery-powered product(come from hqew.net)
  2. Utilizing the circuit designs perfected for recently introduced Quad Operational Amplifiers, these dual operational amplifiers feature 1) low power drain, 2) a common mode input voltage range extending to ground/VEE, 3) single supply or split supply operation and 4) pinouts compatible with the popular MC1558 dual operational amplifier. The LM158 series is equivalent to one
