11 -
About grsparks
- Birthday 05/27/1956
grsparks's Achievements
1
Jordan&tiffany reacted to a post in a topic: An excellent electronics manual
RS232 to 20ma current loop converter
grsparks replied to grsparks's topic in Electronic Projects Design/Ideas
After AT, PC com ports no longer support the current loop option. The current loop is used for higher speeds and longer distances than regular RS232. It might be in the original specification, but not in all the products. There are lots of devices that use this today because higher distance, noise immunity and speed it provides. It is also used in sensors and control applications. I see lots of commercial products out there which perform this function. I just wanted to build one. I am not sure of the difference between current loop and RS485 (long wire extended or 2 wire RS232) but one company offering products had a version for both. Incidently, because I need this for a printer, I could get by fine with a half duplex version, 1200 baud - not really speed critical. -
interfacing a webcam to an external ram
grsparks replied to force's topic in Electronic Projects Design/Ideas
1 mp digital cameras are a dime a dozen these days and take a better still then many web cams I've seen. They come ready to go with ram. I would open one up and run external wires to the shutter switch and the battery connectors. Many will plug right into a usb on a laptop. -
Long distance car sensor.
grsparks replied to Um...Me123's topic in Electronic Projects Design/Ideas
If you can cover the area with a wireless camera, and feed the receiver into the usb port of your computer with an adapter or into a video board, there is software available to monitor the image for movement. The pc could take a snapshot and alert you with a tone. I tried this trick on my driveway but the camera I selected had poor nite vision capabilities. The software I found on the internet was shareware. -
I am looking for a schematic for an RS232 (from a PC serial port) to a serial receipt printer that uses 20ma current loop on a DB25 connector. If I am not mistaken, it should be able to be done with a couple opto- isolators (transistor).
Does anyone have a chart or link with many of the symbols identified that are found on the semiconductors and ICs? It can be the first place to start in locating the datasheet.
??? The 12volt 4amp external switching power supply for my lcd monitor burned out. On the back it states it is a "level 3" I found another 12volt 4amp switching power supply that states it is a "level 1" power supply Does anyone know the difference between these and if it is risky to run the lcd with a level 1 power supply?
After running across this at the public library in town, I just had to order my own copy: "Practical Electronics for Inventors" by Paul Scherz It covers just about everything from DC to Microcontrollers and is well illustrated.
