Soldertraining
19 -
Days Won
2
Everything posted by Soldertraining
The clipping circuit does not have energy storage elements like capacitors but it includes both resistors and transistors. This circuit is normally used for the selection in the transmission purpose. The ability of diodes to allow the flow of current in only one direction. A diode is best tested by measuring the voltage drop across the diode when it is forward-biased. A forward-biased diode acts as a closed switch, permitting current to flow. No voltage exists at the diode but voltage may be present in the circuit due to charged capacitors.
A capacitor is an electronic component having passive two terminal which stores electrical energy in an electric field. The capacitor stores electric charge on its conductive plates. The charged plates separated by the dielectric create an electric field.
A power supply is an electronic device which supplies electric energy to an electrical load. Can anyone tell me what is the minimum power required 1 ton AC.
Transformers pass alternating current and normally are used to step up or step down voltage. The reason to change or replace the transformer is to fix damaged that can be caused by gross under loading and impedance mis-matching, among other things. Transformers can carry dangerous levels of electrical power, so be careful while replacing the transformers, it may cause serious injury or even death. The replacement transformer must be a low-voltage dry-type, meeting or exceeding the TP-1 efficiency standard. The rated size (kVA) of the replacement transformer must be equal to or less than the existing transformer replaced.
Are looking for new good information about electronics?
Soldertraining replied to a topic in Electronic Resources
Yes, I am looking for good web links which provide intensive information about electronics especially PCB electronics. Earlier I have read some website of electronics like solder.net, IPC.org and ipctraining.com websites which gives me a lot of info about IPC courses also. -
Silicon photonics is an evolving technology in which data is transferred among computer chips by optical rays. Optical rays carries more data in less time than the electrical conductors.
The study of very small electronic designs and components can be termed as microelectronics. These devices are made from semiconductor materials. Microelectronics uses unique wiring techniques for wire bonding.
Study of very small electronic components design and manufacture is known as Microelectronics. It consists of inductors, capacitors, resistors, transistors, conductors, and IC's . I am quite interested in microelectronics, especially in printed circuit board. I expect some help with reference from my guest in this forum.
IPC is a networking organization, advocacy arm and not for profit repository of electronics industry standards. It provides a variety of networking events where industry leaders, technocrats and business people involved in the electronics industry can meet, learn and share ideas. In addition, the organization gathers and organizes industry standards with respect to materials, processes, and inspection having to do with the assembly, testing, and sourcing for the electronics industry. Also, these IPC certification programs are important to maintaining the integrity and consistency of the build quality of electronic assemblies across a variety of industries and applications.
- 1 reply
- ipc certification
- solder training
(and 1 more)
Tagged with:
The colors of capacitors describe the types of capacitors. The color used to identify the components or parts on the circuit board. The round blue colored balls with dots indicate that its a capacitor. Same as other colors are used for other components.
PCB manufactureres
Soldertraining replied to jknightandkarr's topic in Sell/Buy electronics - Job offer/requests
PCB Manufacturer uses: Front-end tool data preparation, Preparing the photo tools, Print inner layers, Etch inner layers, Register punch and Automatic Optical Inspection (AOI), Lay-up and bond, Drilling the PCB, Electroless copper deposition, Image the outer layers, Plating, Apply solder mask, Silk-screen and cure. -
Learning about electronics concept needs more concentration and penetration to understand the PCB, BGA, Soldering, Reballing etc....If you choose the electronics, your future will be brighter. Thanks
Electronic Component Organizer App
Soldertraining replied to AVRMike's topic in Electronic Resources
Thanks for sharing Electronic Component Organizer App. I think it could be very helpful to me and also for others.- 5 replies
- windows
- components
(and 3 more)
Tagged with:
Best electronic products can get by the following process: Select the core electronic components Design the circuit schematic create the bill of materials design the printed circuit board order the PCB prototypes Program the microcontroller or microprocessor Evaluate, debug, and repeat certifications
To identify and locate information for electronics components you can recycle from discarded gadgets. Some of the electronics components are: 1 Diodes2 Piezo Buzzer3 Transistor4 Transformer5 Relay6 Inductors7 Integrated Circuits (IC’s)8 Capacitors9 Crystal10 Resistors
It is used in conjunctions with solder in order to remove oxidation from the base and filler metals involved in soldering. All solder fumes can cause occupational asthma and other health problems.
