Dmitry
21 -
Everything posted by Dmitry
My personal user-case on how to make Skype work great on Raspbian. For me, this result seems a bit faster and more stable video streaming and less overall lagging. Learn from my Skype on Raspberry Pi article. P.S. This guide is likely to be applicable to other ARM devices.
- raspberry pi 2
- raspberry pi 3
- (and 8 more)
There are a lot of ways to use the Raspberry Pi (and other ARM-based) mini computer boards. I've wondered if it's possible to make up something like a music controller hub center with Spotify. So, read my experiment about running Spotify on RPi
- raspberry pi 2
- raspberry pi 3
- (and 10 more)
A lot of people asking if it's possible to play games on Raspbian. More than possible! Learn different ways of playing games on Raspberry Pi in this article - https://eltechs.com/gaming-on-raspberry-pi
- 3 replies
- raspberry pi gaming
- rpi games
- (and 9 more)
With the possibility of 3D hardware graphic acceleration on Raspberry Pi, it becomes much easier to play great PC Games on RPi. Thanks to OpenGL and new ExaGear emulator feature. Learn more from the article above.
- 2 replies
- rpi gaming
- rpi3
- (and 9 more)
There is a real necessity in a TeamSpeak server to organize communication channel between two and more people. Also, it needs to to be built in a cost-efficient and tech-savvy way. And so, I've come to the solution - build TeamSpeak 3 server on Raspberry Pi (or any other ARM device). Learn this case and try to do this on your ARM.
- raspebrry pi
- raspberry pi 2
- (and 9 more)
To emulate any type of software on any ARM development boards like Raspberry Pi a Virtualbox software is usually used. Learn the Virtualbox alternative for RPI (or any other ARM) with greater performance.
- raspberry pi 2
- raspberry pi 3
- (and 11 more)
Another and less complicated way to enjoy Plex on your Raspberry Pi (or any other ARM Device)
- raspberry pi
- raspberry pi 2
- (and 8 more)
It's great when you've got your own cloud storage server. OwnCloud is the one, that can help. Especially, if set up on an ARM-device (like Raspberry Pi) it is also savvy and simple. Learn my experience how I have succeeded to install OwnCloud on Raspberry Pi (if you like it and have some other ARM device, go ahead and try this tutorial. Post the results to this topic)
- raspberry pi 2
- raspberry pi 3
- (and 6 more)
There are two emulators: ExaGear Desktop and QEMU. So, I've decided to carry out a fair survey and compare the performance of these two. Without the bias, here are the results in QEMU vs ExaGear performance comparison article ----------------------------- P.S. To make sure, carry out your own experiment and post the results to this topic. What if you will get the different output?
Communication is great when it's easy and free. Here is the way to setup the popular messenger Telegram on Raspberry Pi
- raspbian
- raspberry pi project
(and 2 more)
Tagged with:
Free open-source and cross-platform alternative to Microsoft .NET Framework is Mono and it also can be ported to Raspberry Pi. Read more: Mono on Raspberry Pi
- raspberrypi
- raspberry pi roject
- (and 4 more)
What if Windows can be started on ARM devices? Do you really need to reach your goals? The answers are in the article: Windows 7 on Raspberry Pi
- raspberry pi projects
- raspbian
(and 7 more)
Tagged with:
3 ways of playing games on ARM devices. Arcanum, Desciples II, Ceasar III, Fallout, Heroes and more in the article Gaming on Raspberry Pi (the guide works for any ARM device)
Another way of playing great PC games on Raspberry Pi. Simply turn your device into a fast Raspberry Pi gaming emulator
- raspbian
- (and 3 more)
Some developers really need MS .NET Framework for some reason on their ARM devices (mainly on Raspberry Pi). So, basing on their requests, I have made a short tutorial on how to setup .NET on Raspberry Pi.
An interesting case of using different pieces of software on ARM-based devices (Raspberry Pi, Odorid and NanoPC) includes WPS Office and Adobe Acrobat Reader. Here are the details - https://eltechs.com/miracles-still-happen
TeamViewer, VNC or SSH + X11 are the 3 ways to run a remote desktop on Raspberry Pi. Learn the details from my article and chose the best one for you.
- raspberrypi
- rpi
- (and 3 more)
If you need to build up an automatic backup process on an ARM device, learn this tutorial for setting up CrashPlan on Raspberry Pi as an example. You may use this for any ARM-based device as well.
- raspberrypi
- raspberry pi
- (and 5 more)
