PalGreen
Members
  • Posts
    4
  • Joined
  • Last visited
Everything posted by PalGreen
  1. Personally, for me an integral part in technical development is economic calculations, that's for them I use this resource https://books.google.com.ua/books?id=GDBWBQAAQBAJ&pg=PA28&lpg=PA28&dq=technical+developments+are+economic+calculations&source = bl & ots = KMJ36kWrHU & sig = hdm8d45WiiNuFEZtfvMg0-9PFZE & hl = en & sa = X & ved = 0ahUKEwippsj1jJHXAhUHEpoKHWKfDDsQ6AEIJjAA # v = onepage & q = technical% 20developments% 20are% 20economic% 20calculations & f = false Also sometimes I use https://essayshark.com/personal-statement-writing.html If my advice is helpful, then I will be glad to listen to any criticism, suggestions. If you have any more materials, ideas, then you can share with me. Thank you!
  2. // Create a timer that will fire every second var timer = new System.Timers.Timer (1000); // Assign a handler that will fire on timeout timer.Elapsed + = OnTimeout; // The timer will always work timer.AutoReset = true; timer.Enabled = true;
