Yes, you can buy basic TTL Chips from Digikey or Amazon. BTW here is the closest I could build up to your specs. I did not use the 7432 OR gate though. Just made a 5 input 7400 NAND gate. When the output of x1 x2 x8 x16 x32(∑=59, because the base10 is one less than the MOD# ie mod#-1=Base10) goes active HIGH activates all the AND gates to go High. When this happens it activates the NAND gate to be a LOW state. This causes the clear inputs of the 7476 JK flip-flops to clear and start the count at 0.
Also, please note that the least significant bit(LSB) is on the left, and the Most significant bit (MSB) is on the right.
