ante
Members
  • Content Count
    4,138
  • Joined
  • Last visited
1 Follower
About ante
  • Rank
    Advanced Member
Recent Profile Visitors
  1. From what I have seen they use pulse transformers to trig from a lower voltage to achieve simultaneous response.
  2. If the inverter is dead, check the SMD fuse on the inverter board.
  3. Did you find any fluid leaks during the cleaning of the tubes? Are you sure you got it back together the correct way after cleaning?
  4. Omni, you look kind of young and unfocused (on your avatar) to be a tube mechanic! ;D
  5. If someone else does your homework you will never learn the stuff yourself! Does this make any sense to you?
  6. Thanks Walid! I miss May and June of 2007, you don
  7. Hi Jeff, One of these should do it: http://www1.uk.conrad.com/scripts/wgate/zcop_uk/~flNlc3Npb249UDkwX0NPUF9VSzpDX0FHQVRFMDU6MDAwMC4wMTI2LjlhYjI3ODYzJn5odHRwX2NvbnRlbnRfY2hhcnNldD1pc28tODg1OS0xJn5TdGF0ZT0xMjYxMjE4Nzk3====?~template=PCAT_AREA_S_BROWSE&mfhelp=&p_selected_area=%24ROOT&p_selected_area_fh=&perform_special_action=&glb_user_js=Y&shop=UK&vgl_artikel_in_index=&product_show_id=&p_page_to_display=DirektSearch&~cookies=1&zhmmh_lfo=&zhmmh_area_kz=&s_haupt_kategorie=&p_searchstring=&p_searchstring_artnr=187151&p_search_category=alle&r3_matn=&insert_kz=&area_s_url=&brand=&amount=&new_item_quantity=&area_url=&direkt_aufriss_area=&p_countdown=&p_80=&p_80_category=&p_80_article=&p_next_template_after_login=&mindestbestellwert=&login=&password=&bpemail=&bpid=&url=&show_wk=&use_search=1&p_back_template=&template=&kat_save=&updatestr=&vgl_artikel_in_vgl=&titel=&darsteller=&regisseur=&anbieter=&genre=&fsk=&jahr=&jahr2=&dvd_error=X&dvd_empty_error=X&dvd_year_error=&call_dvd=&kna_news=&p_status_scenario=&documentselector=&aktiv=&p_load_area=$ROOT&p_artikelbilder_mode=&p_sortopt=&page=&p_catalog_max_results=10
  8. Wrong attitude = no help! ;)
  9. Sorry, that looks like a custom made IC!
  10. I would go for a Li-Po since they are light weight and small for a handheld device like this. Perhaps it is a good idea to use a replacement battery for a cell phone, they are nice and compact. The one I have got in my cell is 6 x 39 x 65 mm 3.6Volts and 1200mAh 26g as an example. ;)
  11. Not enough info, what is it? What voltage? What is the expected use and run time? How much current does it require, is it constant or erratic? Used inside or outside, in winter?
