willis
Members
  • Content Count
    5
  • Joined
  • Last visited
About willis
  • Rank
    Newbie
Recent Profile Visitors
  1. thank you for sharing,do you know the site to download some datasheet and electronics file
  2. MALVERN, Pa., Oct. 08, 2018 (GLOBE NEWSWIRE) -- Vishay Intertechnology, Inc. (NYSE: VSH) introduced four new 100 V and 120 V TMBS® Trench MOS Barrier Schottky rectifiers that provide up to 20 mV lower forward voltage than previous-generation devices. The Vishay General Semiconductors V30100CI, V30120CI, V40100CI, and V40120CI offer current ratings of 30 A and 40 A in the TO-220AB package. With their low forward voltage drop down to 0.36 V at 5 A, the rectifiers released today reduce power losses and improve efficiency in high frequency DC/DC converters, switching power supplies, freewheeling and OR-ing diodes, and reverse battery protection. The devices are ideal for 65 W USB Type-C power delivery for notebook computers and mobile devices. The new rectifier is RoHS compliant, halogen-free and has a maximum operating junction temperature of up to +150 °C. Its TO-220AB package can withstand solder bath temperatures up to 275 °C as specified by JESD 22-B106 for 10 seconds. The four product models and applications of MOS Barrier Schottky rectifiers are basically the same. You can refer to the datasheet. I will list the description of V30100CI. The information of V30100CI Dual High Voltage Trench MOS Barrier Schottky Rectifier Ultra Low VF = 0.43 V at IF = 5 A FEATURES • Trench MOS Schottky technology • Low forward voltage drop, low power losses • High efficiency operation • Solder bath temperature 275 °C maximum, 10 s,per JESD 22-B106 TYPICAL APPLICATIONS For use in high frequency converters, switching power supplies, freewheeling diodes, OR-ing diode, DC/DC converters, and reverse battery protection V30120CI datasheet V30120CI datasheet Learn more Technologies about Vishay Semiconductors
  3. here you can find the electronic parts you want,newark and arrow can supply,but their quantity is large I think find a distributor is good idea,they can promise the quality
  4. The new Magnetic Sensor Programmer (MSP) V1.0 replaces APB 1.5, forming a complete line of programming tools for Micronas products. What is the benefits · Suitable for HAL 18xy, HAL/R 24xy, HAL 28xy and HAL/R/C 37xy series products. · MSP V1.0 can drive high voltages and operate the latest generation of sensors with PSI5 outputs. TDK Corporation has expanded its programming tool chain, and the Magnetic Sensor Programmer (MSP) V1.0 makes it easy to program a wide range of Micronas products. MSP V1.0 replaces APB 1.5 and other existing programming tools, which combine USB-Programming Kit V1.01 and HAL APB V5.1. This programmer is especially suitable for development labs. TDK now has three tools to support all Micronas programmable sensors. MSP is suitable for all products of HAL 18xy, HAL/R 24xy, HAL 28xy, HAL/R/C 37xy, and the angle sensor products to be launched next. These products are primarily used in position detection and angle measurement applications in automobiles, such as throttle valves, accelerator pedals, EGR valves, neutral detection, gearbox gear sensors, folding lights, and steering wheel angle applications. In addition, in the field of industrial electronics, programmable linear sensors HAL 18xy and HAL 24xy are used for current measurement, joysticks, rocker switches, and various extended position measurement requirements. To optimize the system performance of the above applications, a single sensor needs to be programmed. To this end, TDK provides the corresponding hardware and software. Compared to its predecessor, MSP is able to drive higher currents and operate the latest Micronas sensors with PSI5 output. With its RS-232 or USB interface, MSP can be easily connected to a single computer. TDK provides specialized software to support the command interface for communicating with a computer. Support for specific computer software for engineering or development purposes. Programmable Hall sensors have special software to provide a graphical user interface based on LabViewTM. Customers who currently use APB 1.5 can easily switch to MSP because they are compatible with previous software. This simple programming approach provides customers with improved productivity and optimized sensor performance.
