15 -
Days Won
1
Holy Hathaway last won the day on August 28 2019
Holy Hathaway had the most liked content!
About Holy Hathaway
- Birthday 02/03/1996
Contact Methods
Website URL
http://www.apogeeweb.net/
Profile Information
Gender
Female
Location
China
Recent Profile Visitors
3,252 profile views
Holy Hathaway's Achievements
I’ve got a 4 bladed drone that can run without a controller 2. Once in the air it’s programmed to follow you via a tracker beacon and the on board sensors or an automatic computer program. Although it comes with one anyway so you can do tricks and more complex moves, but other than that it’s fully automatic and requires no assistance. I use it for film and checking stuff on my farm.
My question : how can we replace the relay in a battery charger by one or two MOSFETs? I imagine a P MOSFET mounted as a polarity protection and directly charging the battery through a schottky, and the voltage of the battery sensed by a BJT thru a voltage divider that will block the MOSFET as the battery reaches 14 volts or so. What would be the values of the components : transistor (N? P?), voltage divider... Can you explain on that?
I am having huge difficulty with op amp circuit used in TA7642 radios, I cannot figure out how to attach the lm301 chip to have a gain of more than 200 (10 u cap between pin 1 and if I give it too much signal in 50 k ohm pot then the radio just makes a farting noise. My problem is that I need to figure out which lowpass or highpass filtrations between the speaker pin 5 and the 470 n capacitor and which resistors I need to reduce the hissing noises without any distortion or clipping when I try to make it louder.
I have one question. Most IMUs now a days have built in sensor fusion using kalman filters. For instance, Mbientlab-MetamotionR IMU. Now i would be getting angular rate from gyroscope. So how the sensor fusion works in this case (built in sensor fusion)? because if i want to get angle of rotation then i integrate the angular rate and get drift in the measurement.
Hello, I am wondering if I can replace the speaker with 3.5 mm audio jack and input the audio to my laptops microphone in so I can record the sound using a software such as audacity. I don't know the input specifications and afraid that inputting amplified voltages over 5 volt would damage the microphone input port of my laptop. Thanks in advance for your reply.
I wonder if TDA7498 class D amp could be used as a substitute for a dead STK power module running at 39 Volt. If I remember well a class D amp needs the grounds of the output channels to be separated. One shared output ground, like in a standard amp chassis, may kill the class D amp. Anybody?
I'm programming ATtiny13A with arduino. I want to use "stepper.h" library but it seems it is only supported on arduino or atmega series but not on attiny. Is there any way I can fix it? Thank you!
Can I replace MPXV7002DP transducer by MPXV7002DPT1?
Holy Hathaway replied to Holy Hathaway's topic in Projects Q/A
thanks mate, really helpful! -
Holy Hathaway reacted to a post in a topic: Can I replace MPXV7002DP transducer by MPXV7002DPT1?
Can I replace MPXV7002DP transducer by MPXV7002DPT1? Hi all, I bought a MPXV7002DP transducer after reading a detailed introduction article about this device, here's the link: MPXV7002DP. It says that MPXV7002DPT1 is the alternative of MPXV7002DP. But it didn’t give me their comparison about specifications. I’m not the expert at transducer... The problem is after I got this device I found out that I got a MPXV7002DPT1 at home already, so are these two can be used interchangeably?? Thank you!
How is the current generated? The current is generated because of the positive and negative charges. The electrons are inside the metal conductor and actually flow from the negative electrode to the positive electrode. It can be imagined that there is a positive charge on the positive side of the power supply. Inside the metal conductor, the nucleus has little force on the electrons, and the electrons are easily separated from the nucleus. So the electrons in the metal conductor close to the positive electrode of the power source are first attracted by the positive charge of the positive electrode of the power source. In the past, the metal conductor that is close to the positive pole of the power supply loses electrons, and it becomes a positive charge itself. The free electrons of the metal conductor that follows it are attracted by this positive charge, and thus the current is formed. If the nucleus of a certain metal has a strong attraction to electrons, then the electrons move hard, which can be understood as "resistance is large". If the nucleus has a weak attraction to electrons, then the electrons move easily. Kind of situation can be understood as "small resistance" In fact, when the free electrons move in a direction, they will collide with the atoms on the crystal lattice. According to the classical conductivity theory of metal, the free electrons collide with the positive ions on the lattice, and the electron motion is hindered to generate resistance. The collision frequency is about 1015 times per second. In the microcosm, it is not advisable to understand with simple particles. In the atomic model, electrons outside the core are distributed according to certain rules. According to the principle of uncertainty, it is impossible to judge the position of the electron at the moment. Only the region where the electron is distributed has a probability distribution. The distribution map of the electron is called an electron cloud. The state of the electron can only be known through the electronic cloud. When an atom is excited by the outside world, the electrons will break away from the control of the nucleus and become free electrons. But the electrons will soon release the excited energy and then return to the electron cloud. Because the number of atoms in a conductor is a huge astronomical number, and the atom is in a state of being excited by heat, statistically, because the number of atoms in the conductor is huge, the number of free electrons is of course huge, so that the whole The conductor looks like a sponge filled with free electrons. From the perspective of energy, the electrons in the electron cloud are controlled by the nucleus, as if they are locked into a dense space. While the energy of free electrons is relatively high, it can move relatively freely. The energy relationship of the former can be called the forbidden band, and the latter is called the conduction band. The electrons move and return between the forbidden band and the conduction band. The function of the power supply is to establish an electric field that acts on the free electrons that satisfy the condition, causing it to move in an directional motion. Electrons are accompanied by excitation and return during motion, which is part of the resistance. Therefore, electrons can't actually be compared with ordinary physical particles. The two are actually different. Of course, you can understand it simply by particle model. The excitation of an atom involves the thermal motion of the atom, so the amount of free electrons is naturally closely related to the temperature of the material, as the resistivity increases with temperature. More articles about resistance and current, visit: Kynix semiconductor electronic blog
The 555 timer is a medium-sized integrated circuit developed by Signetics in 1972 to replace mechanical timers. It is named after the input is designed with three 5kΩ resistors. This circuit later became popular in the world. At present, there are four popular products: two BJTs: 555, 556 (with two 555); two CMOS: 7555, 7556 (containing two 7555). The 555 Timer is a mid-scale integrated device that combines analog and digital functions. It is called 555, which is usually fabricated by bipolar (TTL) process. It is called 7555 by complementary metal oxide (CMOS) process. In addition to single timer, there is corresponding double timer 556/7556. Its power supply voltage range is wide and can operate from 4.5V to 16V, the 7555 can operate from 3 to 18V, and the output drive current is approximately 200mA, so its output is compatible with TTL, CMOS or analog circuit levels. The 555 chip is an extremely versatile chip with up to hundreds of different applications including time-base timing or switching and voltage controlled oscillators and regulators. For those who have been exposed to digital or analog circuits, the 555 chip is definitely a classic. With its low cost and reliable performance, it is widely used in various electrical appliances, including instrumentation, household appliances, electric toys, and automatic control. Its various pin functions are as follows: Pin 1: external power supply negative terminal VSS or ground, under normal grounding. Pin 2: Low trigger terminal TL, this pin voltage is valid when it is less than 1/3 VCC. Pin 3: output OUT. Pin 4: directly clear the terminal RST. When this terminal is connected to a low level, the time base circuit does not work. At this time, regardless of the level of TL and TH, the time base circuit output is “0”, and the terminal should be connected to a high level during normal operation. Pin 5: CO is the control voltage terminal. If the pin is externally connected, the reference voltage of the two internal comparators can be changed. When the pin is not used, the pin should be grounded into a 0.01μF (103) ceramic capacitor to prevent high frequency interference. Pin 6: High trigger terminal TH, this pin is valid when the voltage is greater than 2/3 VCC. Pin 7: discharge end. This terminal is connected to the collector of the discharge tube T and serves as a discharge pin for the capacitor at the time of the timer. Pin 8: external power supply VCC, bipolar time base circuit VCC range is 4.5 -16V, CMOS type time base circuit VCC range is 3-18V, generally 5V.
