AN920
Members
  • Content Count
    359
  • Joined
  • Last visited
  1. Do you mean, (serie-shunt,shunt-shunt,series-series and shunt-series)? http://www.ece.mtu.edu/faculty/goel/EE-4232/Feedback.pdf http://www.scribd.com/doc/92675/EE3102-Experiment-1
  2. Here are some pictures showing the 100 kHz noise pulses into the VCO tuning line. In the first picture it is not easy to spot the problem. The scale is 1mV/div The next picture shows the pulses after I averaged it 64 times. The 100 kHz pulses can be clearly seen. These pulses are very narrow. You won't even see them on a 20 MHz BW scope.
  3. You need to provide more information 1) Which IGBT's are you using? 2) What size motor are you driving? 3) What type of load. Pump, fan etc. Under which conditions do they fail?
  4. Hi Sarma, No, that won't help as I will show below. If you look at the first plot, you will see that with the 47nF connected between the base-collector of the MPSA13 the gain at 100 KHz is about 6.5dB. This is the problem I suspected. In the second plot, by moving the 47nF to the base-emitter of the MPSA13 you make the problem much worse. Now you will have 14.5dB at 100 kHz. No good. The last plot shows putting the capacitor at the 2nd base of the pair of 2N3904's. I increased the value from my previous suggestion after doing a simulation to 22nF. Now the gain at 100 KHz is zero. With my original value of 10nF there was still about 1dB gain at 100 kHz.
  5. A good friend of mine in Australia bought one of these kits. He was having some problems getting it to work properly. He posted it to me to look at. Here are my findings and some modifications I did. I will address it point by point: 1) Move this cap closer to pin 12. The PLL Vcc is very sensitive to any noise. (see pcb layout below) 2) Run the VCO tuning supply from a higher voltage than 5V. It must be regulated. This can be another small 78L09 or suitable zener. This will help locking at bottom and top ends of the band without readjusting L1. 3) Reduce the 5.1k to about 2.7k (It will allow faster tuning). The 22k On the base of Q1 can also be made slightly smaller with not much effect on performance. 4) Try a variable capacitor there to alter the phase of the pilot for best stereo separation. You can replace it with a fixed value after measuring on a LCR meter. 5) Try to get the ratio of the (22pF, 33pF and VC1 to 10pF) as high as possible. This means the total capacitance by the 3 elements in the circle should be as large as possible while the series cap (10pF in this case) should be as small as possible. L1 should be as small as possible. This may take some experimentation to get values that will provide lock at the top and bottom end. If you operate on a single frequency this is not a problem. This will give lowest carrier noise sensitivity for this clapp oscillator. 6,7) I found some slight loop instability (hunting) when tuned to the high end of the band. This sounded like a faint whistle on the audio. I think it is caused by some of the 100 kHz comp reference still getting into the VCO tuning line from the output of the charge pump. I solved this by using 2 separate transistors for Q1. This gave me access to the base of the second transistor. I removed the 47nF and placed a smaller 10nF (make this 22nF, see next post) as shown. This cured the instability and noise problem. When you set up your transmitter at the low end and your voltage at TP1 reads lower than about 0.7V or is stuck at 0.6V then the VCO can
  6. Someone suggested the faster LT1353 to extend the operation to over 100 KHz. I will look into this. The PIC clock will have to be much faster for the counter.
  7. The current probe or current transformer method was suggested by Dr. Middlebrook long ago. Every injection point has its pros and cons. I think where a loop is very marginally stable various methods may make a small difference, but where it shows obvious instability it won't make much of a difference. By using the better driver we can get it unconditionally stable, so why not? The price is only $0.18 Someone who tests the supply for load switching may see no oscillation, because of high ESR output cap. He will see a voltage dip and overshoot when the load is removed. The real test will be with a high grade (switchmode type) electrolytic with low ESR.
  8. When I started to fly RC planes long ago (I don't anymore), I started with a STIK-40 with a tuned pipe. Radios with 4-6 channels were expensive. There were many beginners who had 2-chan radios. When the local club found out that I was into electronics, everyone wanted me to repair and check their radios. I then made a big mistake of modifying a normal 2-chan radio to 3-chan so that at least you could fly with rudder, elevator and throttle control on a dihedral wing craft. I added another pot with a lever and some extra circuitry to the transmitter as well as a decoder expansion with some 4013 and 4017
  9. If you are referring to the bode plots of the PSU loop stability, that was injected with a current transformer inserted into the feedback path. I could have injected in the error amp's own feedback path as preferred by some people. In this case I don't think it will make much difference.
  10. Hi Omni, I used to have a Quad tube amp that sounded great. Only 15W rms but outperformed the 50 W transistor amps. Today I am sorry that I traded it for an old RF Motorola signal generator back in high school.
  11. Future Electronics have 10,000 + in stock at $0.18 ea. FC shows it is still in full production http://www.fairchildsemi.com/pf/MJ/MJE180.html
  12. I think I found a possible replacement. Look at the MJE180 from Fairchild. http://www.fairchildsemi.com/ds/MJ/MJE182.pdf Good, Ft (50 MHz), gain (50 min) and Ic (3A) Initial simulations look very good. Very stable with low ESR values and very fast loop load-step response (200nS). I will analyze this further, but it looks good. Mouser have them for $0.60 ea.
  13. That was the intention in the original design with a much better transistor. The whole picture changed. The situation will be the most problematic during load switching of high currents. It will be the worst at high output voltage settings and will get worse with lower ESR values. As-is, a 10uF cap with any ESR lower than 5 ohm will cause oscillation when switching.
  14. Sorry, Walid I will respond more in detail when I have more time.
