21 -
russlk's Achievements
Please tell me the alternatives of these
russlk replied to shaiqbashir's topic in Datasheet/Parts requests
High frequency crystals are of the overtone type and will not oscillate at the correct frequency in that circuit, if it oscillates at all. -
I would forget the capacitor and find a solonoid coil, like used in a washing machine water control. Get an iron rod from the local hardware store that will fit in the coil, an iron or brass washer that will also fit the rod. When 110VAC is applied to the coil, the washer will be propelled up the rod. If you still want to use a capacitor, get a 200 volt, 400 microfarad cap and charge it with a bridge rectifier on the 110 volt line.
For safety, keep one hand in your pocket and wear rubber soled shoes or work on an insulated surface. The high voltage won't injure you but you could be injured when you jump back. If you have overheating components, you have to find the cause before replacing parts. Check leakage of filter caps, etc.
You think it is overheating? Put your finger on it. If you get burned it is too hot, if not, that is not your problem.
You can't use the reactance as a plain number, you have to consider the phase angel. The current leads the voltage by 90 degrees in a capacitor and lags by 90 degrees in an inductor. The reactance of an inductor is given by Xl = 2*PI*f*L where PI=3.14162, f= frequency in Hz, L=inductance in henries. The reactance of a capacitor is given by Xc = 1/(2*PI*f*C). The quantity 2*PI*f is given the symbol ohmega, but since I don't have that symbol on the keyboard, I will use W. The 90 degree phase angle is denoted by j, so now Xl = j*W*L and Xc = 1/(j*W*C). The advantage of this nominclature is that it is easy to add series impedances: Z = Xl+R = j*W*L+R Parallel impedances is the familiar product over sum: Z = j*W*L*R/(j*W*L+R). You can convert a parallel circuit to an equivalent series circuit and vice-versa. I used to be able to practically do that in my head, but it has been many years.
The gain of T1 is nominally RV1/R6, but there is negative feedback thru R2, so the computation is complex. The purpose of R6 is to stabelize the DC current and increase the input resistance of T1. The input resistance is rb+beta*R6. Probably around 4700 ohms. The input capacitor (100nF) is working against the 4700 ohms, which gives an high pass cutoff of 340 Hz. You need a larger input cap to get good bass. Voice frequencies are about 300 Hz and up, so you need low pass starting at 100 hz or lower to have any attenuation at 300 hz.
L2 resonates with C5 and C4 near the center of the TV band. A 75 ohm resistor would probably work as well. L1 is a "peaking coil". It is self resonant near the upper edge of the band and is there to raise the high frequency gain. You cannot put a pot in this circuit because the leads have to be very short and this is a high frequency circuit. The ratio of C5, C4 could be changed, keeping the total constant, to change the gain. FYI: the total is (c5*c4)/(c4+c5).
The basic problem is that radio waves travel at 186,000 MILES per second, so 1/8 inch is such a small time you would be extending the state of the art several orders of magnitude if you got this idea to work.
mF means millifarad, but that is an error, it should be uF. The european style is to use , instead of. so it is 4.7uF. #18 wire is rather large and I would not space the turns, use close wound and at least 8 turns. The 4 turn inductor is .132uH if you use #18 wire, close wound.
Transmitting 30 watts without a license is probably highly illegal. A directional antenna can boost the signal without getting you in hot water. The ARRL antenna book is a good source of info.
The result of a measurment will depend on how it is done, and the method should relate to the way is is going to be used. If the secondary is to be grounded, the measurement should be done that way. If the transformer includes a faraday shield, the common mode will be nil and hard to measure. I have not had to do this measurement, but I would tie the two primary wires together and drive them relative to ground with a signal generator, measure the signal at the secondary terminals and call the common mode rejection the ratio: sec/pri volts or dB.
Help with code transmission in RF or IF
russlk replied to mailboy1983's topic in Electronic Projects Design/Ideas
The RF is just the carrier, the DTMF tones will all ride on it. The receiver will seperate the tones using filters, each one identifying a bus. simple tones could be used because the probability of interference is low and signal to noise will be high. -
sensitive low frequency filter
russlk replied to electrodoc's topic in Electronic Projects Design/Ideas
This circuit will provide the lowpass and adjustable gain: -
Help with 60 second stopwatch project
russlk replied to Canas's topic in Electronic Projects Design/Ideas
There is not enuf information here: What is the source of time? What does the output look like? -
power vs. signal frequency
russlk replied to Ldanielrosa's topic in Electronic Projects Design/Ideas
The advantage of AC power is that you can transmit at high voltage and low current, for low loss, and transform back to low voltage and high current at the load. But, 15 VAC is not high enough to be efficient, why not send the power as DC? The signal coming back could be on an AC carrier, or if it is logic could be sent directly with Manchester coding.
