Showing results for tags 'embedded'.
  • Search By Tags
  • Search By Author
  • Electronics Forums
    • Projects Q/A
    • Datasheet/Parts requests
    • Power Electronics
    • Service Manuals
    • Theory articles
    • Electronics chit chat
    • Microelectronics
    • Electronic Resources
  • Related to Electronics
    • Inventive/New Ideas
    • Components trade
    • High Voltage Stuff
    • Electronic Gadgets
  • General
    • Announcements
    • Feedback/Comments
    • General
  • Salvage Area
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
Website URL
Yahoo
Skype
Location
Interests
Found 6 results
  1. On November 7th, 2023, Forlinx Embedded launched the Debian 11 system for the first time on their development board, OK3568-C/OK3568J-C, which is based on the RK3568 chipset. Forlinx Embedded officially supports the Debian 11 system on the OK3568-C/OK3568J-C platform. In the field of embedded development, stability and richness are crucial factors. The RK3568, as Forlinx's flagship embedded product, has high performance, low power consumption, and rich interface functions, making it appreciated by industry users. Debian 11 is a stable, reliable, and open-source operating system, which provides a powerful foundation for the OK3568-C. Debian 11 has undergone rigorous testing and validation to ensure system stability, so there is no need to worry about unexpected crashes or data loss. Moreover, Debian 11 has a vast software library, which enables developers to easily install and update required software packages. By combining the advantages of the OK3568-C hardware with Debian 11, developers can fully leverage the diversity of the 3568 hardware interfaces while enjoying the stability and open-source nature of Debian 11. Indeed, this strong combination provides an ideal environment for various embedded projects. When it comes to stability, free and open source, versatility, and vast software libraries, no operating system can rival Debian. Debian is a truly free operating system, and its strength is not only reflected in technology, but also in its active community. Stable Value: Debian stands out for its world-renowned stability. Whether you are building critical business systems or looking for reliable daily desktops, Debian is always the best choice. Debian 11 has undergone rigorous testing and validation to ensure system stability, so there is no need to worry about unexpected crashes or data loss. Free and Open Source: Debian adheres to the concept of free and open source, allowing you to freely use, modify, and share it. This is a truly free operating system. Not only can Debian be obtained for free, but you can also freely view, edit, and distribute its source code. Huge Software Library: Debian has a vast and diverse software library that covers almost any application and tool you can imagine. From office software to entertainment applications, server services to programming tools, Debian has everything in its software library. Not only that, it also provides an easy-to-use package management system, allowing you to easily install and update software. Multi-architecture Support: Debian supports multiple hardware architectures, including x86, ARM, PowerPC, MIPS, etc., making it suitable for various devices and systems. Whether you use a desktop, laptop, server, or embedded device, Debian can provide the ideal solution. Active Community Support: The Debian community is a vibrant place where you can find help, advice, and resources. Both novice and experienced users can participate in the community and receive support. Originally published at www.forlinx.net.
  2. Analog high definition (AHD) is well-known HD-CCTV technology. It was created as an affordable option for long-distance video transmission. It is a digital HD-CCTV system that uses coaxial cable to compress and transmit analog HD video signals. In closed-loop video surveillance applications, video creation, and vehicle surveillance, this technology is more widely used. It is the perfect solution for situations where big amounts of data need to be delivered at low prices due to its uncompressed high-definition video signal delivery. Using coaxial and RCV cables, this technology supports the transmission of video. Additionally, it has a reputation for being able to sustain a constant video signal free from interruption, which is crucial in any circumstance requiring high-quality video images. This made the upgrade much more cost-effective than a complete switch to an IP system, eliminating the need for extensive rewiring. Working of analog HD camera An Analog HD camera is a type of video camera that uses a combination of analog technology and digital processing to capture, store, and transmit high-definition images. They work by capturing and transmitting images in the form of an analog signal. Using security cameras as an example, in more detail, they record an analog video signal for use in a traditional analog CCTV application and deliver that signal via coaxial cable to a digital video recorder (DVR). Each camera is powered by a cable that bundles the power and video cables. The analog signal is compressed and digitalized by the DVR before being saved to a storage device for future retrieval. The DVR is intelligent enough to handle operations like digital zoom, motion detection, and scheduling. Either monitor can be connected to the DVR, or the DVR can be set up to publish via an internal network for viewing on PCs.
  3. Forlinx has officially launched their latest System-on-Module, featuring the powerful StarFive JH7110 RISC-V chip. These versatile SoM and compatible carrier board are now available for order, catering to a wide range of applications including commercial, medical, and industrial automation. Recently, a few embedded products have emerged utilizing the same processor, including the VisionFive 2, Pine64, and Milk-V Mars. However, the FET7110 SoM will be the first product from Forlinx to feature the integrated Jinghong 7110 processor. See the JH7110 block diagram for reference. • JH7110 – 64-bit RISC-V, up to 1.5GHz (quad SiFive U74-RV64GC, up to 5.09 CoreMark/MHz) JH7110 block diagram The JH7110’s GPU integrates the IMG BXE-4-32 MC1 (up to 600MHz) which offers full support for mainstream APIs like OpenCL 3.0, OpenGL ES 3.2, and Vulkan 1.2. Regarding power consumption, Forlinx indicates that the JH7110 is segmented into eight independently switchable power domains. Additionally, the CPU frequency can be dynamically adjusted via software, allowing customers to fine-tune the frequency based on various application scenarios that require flexible control and power consumption. The JH7110 facilitates camera access through both MIPI-CSI and DVP interfaces, with ISP support. It enables video decoding capabilities of up to 4K@60fps and video encoding of 1080p@30fps. Moreover, the SoM supports HDMI (4K@30fps) and RGB (1080p@30fps) display output interfaces, along with MIPI-DSI (2K@30fps). Specifications listed for the FET7110-C SoM include: • Memory/Storage: ○ 2/4GB LPDDR4 RAM ○ 32GB eMMC 5.0 ○ 100 Mbps QSPI ○ SD 3.0/MMC 5.0 • Connectivity: ○ 2x GMAC for RMII/RGMII 10/100/1000 Mbps • Display/Audio: ○ 1x HDMI 2.0 (up to 4K@30fps) ○ 1x 4-lane MIPI DSI, (up to 2K@30fps) ○ 8-lane I2S PCM/TDM • Camera: ○ 1x 4-lane MIPI-CSI • Expansion: ○ 1x PCIe2.0x1, 2 PCIe2.0 controllers integrated w/ PHY • USB: ○ 1x USB 2.0 ○ 1x USB 3.0 • I/O Peripherals: ○ 6x UART, 7x I2C, 7x SPI ○ 1x SDIO ○ 8x PWM ○ 64x GPIOs ○ 2x CAN 2.0B (Up to 5Mbps) • Power: ○ 5V DC • OS: ○ Linux 5.15.0 • Mechanical: ○ 60 x 38mm ○ B2B connectors (3x 80-pin) Specifications listed for the OK7110-C development board include: • Memory/Storage: ○ 2/4GB LPDDR4 RAM ○ 32GB eMMC 5.0 ○ 100 Mbps QSPI ○ SD 3.0/MMC 5.0 • Connectivity: ○ 2x Gigabit Ethernet ports • Display/Audio: ○ 1x HDMI 2.0 port ○ 1x MIPI DSI ○ 2x Speakers ○ 1x Mic • Camera: ○ 1x MIPI-CSI • Expansion: ○ 2x PCIE 2.0 ○ 1x Micro SIM • USB: ○ 1x USB Type-C ○ 3x USB 3.0 • I/O Peripherals: ○ 2x CAN ○ 2x RS485 • Other Features: ○ 1x Power button, 1x Reset key ○ RTC battery • Power: ○ 12V DC (via barrel connector) • Mechanical ○ B2B connectors (3x 80-pin) These products are now available for ordering. Customers can find the product page for the FET7110-C SoM here.
  4. Introducing the FETMX6ULL-S System on Module (SoM) based on the powerful i.MX6ULL processor! This highly adaptable SoM features a dual native Ethernet ports, dual CAN controller, and octa UART, making it the perfect choice for a wide range of applications in various embedded systems and domains. With its compact size of 44*35mm, the FETMX6ULL-S SoM offers a perfect balance between performance and space efficiency. Whether you're working on media playing, digital camera integration, or WXGA display projects, this SoM has got you covered! Not only does it support 24-bit parallel LCD output up to WXGA (1366x768) for crystal-clear visuals, but it also boasts features like a 8/10/16/24-bit parallel camera sensor OV9650, three IIS interfaces, and ALSA audio form for an immersive multimedia experience. The FETMX6ULL-S SoM comes in both industrial-grade and expansion commerce-grade options, catering to various project requirements. Choose from 256MB DDR3L/512MB DDR3L RAM and 256MB NandFlash/4GB eMMC storage options to suit your needs. Rest assured, this SoM is well-supported with Linux 4.1.15 and QTGUI, ensuring a seamless development experience. With support for OTG, SD/TF card flashing mode, and separate kernel updates, you have the flexibility to customize and optimize your projects effortlessly.
  5. Hello Everyone,We are pleased to announce the launch of our online store - Mynics.All of you are requested to check the website and do give us your valuable feedback.You can do the following at Mynics.in- Shop for electronics and robotics- Blogs- Forums- Projects and VideosWe are soon rolling out some great competitions and offers, do follow us to stay updatedhttps://www.facebook.com/mynics.in/http://stalkture.com/p/mynicsinsta/4934651665/https://plus.google.com/104613178419222567531Time to show your creativity and leave the rest to Mynics.Cheers,Team Mynics.
  6. This is the main section of my article in which I am going to give you an idea of different hardware embedded tools and accessories needed to build an embedded system. Of course, you are going to connect components together to form a system, so you require a variety of tools. The components that you need may include sensors, actuators, microcontroller, converters etc. You can find information on components in my article on What is Embedded System? Now let’s talk about the tools in detail. 1. Soldering Iron The first tool among embedded tools that I am going to discuss here is soldering iron or soldering gun. As the name suggests, it is a tool used for soldering. A soldering iron supplies heat to melt a wire. This molten wire fills the space in the joints between two parts. To connect components together, or to fix components on your circuit board, you need to solder them. So soldering iron serves the purpose. A wire is used with this iron which is provided heat so that it melts down. This wire is called soldering wire. Mostly, these irons are supplied with electric current through cords or through batteries. The supplied current heats up the iron. The temperature of iron can be controlled in some models. This tool comes with a stand to keep the hot iron in a safe position. A wax and a sponge may also be provided with the gun to clean the tip after usage. The tip of a soldering iron can also be changed and removed easily. Tips of different shapes and sizes are used for different types of work pieces. A soldering iron is very light weight and easy to carry around. And really a very necessary tool in embedded system development. 2. Desoldering Gun Desoldering gun is also one of the important embedded tools. It is also named as desoldering pump. Desolder means to remove the solder usually from a joint. It serves the opposite function of a soldering gun. Sometimes we need to separate components from each other or to remove components from a circuit board as PCB (printed circuit board). This is required for repair or disassembling operation. So a desoldering iron is used in such cases. A desoldering iron removes the solder by sucking it. Due to this sucking operation, it is named as pump. A suction pump in this tool sucks the molten solder and makes the joint open again. This device is very useful to correct a wrong connected component. 3. Digital Multimeter A digital multimeter or DMM is a testing device among my list of embedded tools. This device is used to measure values of voltage, current and resistance. It is also used to check connectivity between two points. Digital multimeter is a standard testing tool for engineers and technicians. A DMM serves the function of three devices, ammeter for measuring current, voltmeter for measuring voltage and ohmmeter for measuring resistance. All the three devices come in this single package. It consists of a display that shows the measured value, slots for inserting test leads, few buttons such as power button and a switch to select operation you want to use. The test leads are inserted into DMM and then connected to the item being tested to form a closed circuit to the DMM. Measurement values such as volts, amperes or ohms are selected from the switch and result can be noted from the display. It is a very useful and must-have tool for embedded system developer. 4. Oscilloscope The next item in embedded tools is oscilloscope which is a testing device just like a digital multimeter. An oscilloscope is a device used to view voltage signals with respect to time. The signal is represented as a 2-D plot. It is commonly known as a Cathode Ray Oscilloscope (CRO) or simply a scope. An oscilloscope can be used to show more than one signal at the same time. This device is not just used for voltage signals, instead it can be used for other electric signals as well. The waveform represented by oscilloscope is calibrated and different characteristics of wave such as frequency, amplitude, wavelength, time intervals etc. can be measured through it. Now let’s move towards the next item which is a cutter. 5. Cutter A cutter also known as wire cutter or clipper is used to cut jumper wires. Other than jumper wires, you can also use to cut copper, steel or other wires. Other than wire cutters, wire strippers are also used. A wire stripper is used to remove insulation from wires without cutting them. Now I am moving towards the last item on my embedded tools that is a laptop. 6. Laptop Laptop is among the most important tools required for embedded system development. You need a laptop from the very initial stage until the complete development of your product. Your laptop should be equipped with all required software tools that I mentioned earlier and an internet connection. You can search for suitable components for your system, write code and produce file for your microcontroller, simulate your system, have data sheets for all your components in it and much more. All of the tools that I mentioned in this article are essential ones for working on embedded systems. I hope you will find this article informative.
