Melody Posted November 18, 2003 Report Share Posted November 18, 2003 I would like Ideas On how one could build a device to attach to the ground wire of burried cables (such as the telephone company does) to detect the burried cables Location. was thinking of loading the wire with a 440 Mz transmitter through a match box and using a 440 reciever to find the cable. but I am not sure this will work. Quote Link to comment Share on other sites More sharing options...
MP Posted December 11, 2003 Report Share Posted December 11, 2003 There are two different methods used for this. One is a simple metal detector. This is what is used for finding buried cables before digging. You do not have to have a power source in the cable to find it. The other type is an inductive pick up which pulses an amplified votage, then is sent to either an audible source or a visual one. This type of circuit also does not require you to send a signal through it as it is used to sense a signal that is already there. I do not have a metal detector schematic handy, but I am sure they are all over the web. I do have an AC Wire locator schematic, which I have attached. For the coil in this circuit, you can use the type that has a suction cup and attaches to a telephone. These are common in the phone bug projects. This might not be exactly what you are looking for, but might give you a start and hopefully some ideas on making your device. MPAC_Wire_Locator.zip Quote Link to comment Share on other sites More sharing options...
