Jump to content
Electronics-Lab.com Community
Sign in to follow this
HA
STi5518 Datasheet
HI guys, I've a receiver FTA Accessbox by metronic, It's = at another receivers with sti 5518. this is the data of receiver with winupoad 4.0 by null modem cable rs232:
DebugPort initialised to 115200, 8, N, 1
Failed to sense hot keys for the second time ... O[0] N[0]
No download demanded
Verify CRC => Part #01. START [7FF70000] Size[505644] CRC[D15812AB] Ver[ 13 ]
Terminating system services..
UnCompressed Image Size => [ 0x7FF50008 ] Bytes
Decompress Start => [ 0xC0783000 ]
Image Decompressed successfully...
Image StartAddress => [ 0x7FF70000 ]
UnCompressed Image Size => [ 0x7FF70008 ] Bytes
Decompress Start => [ 0xC0080000 ]
Preparing to start application..
BOOT ADDRESS => [ 0xC0192FBE ]
STAVMEM_Init()=Ok
STAVMEM_CreatePartition()=Ok
STEVT_Init()=Ok
STPWM_Init()=Ok
STI2C_Init(back)=Ok
STI2C_Init(front)=Ok
PTI interrupt level 6
src\pti\ptiinit.c 405> Suceesfully enabled the PTI interrupt
PTI_Init()=Ok
STCLKRV_Init(CLKRV2)=Ok
STCLKRV_Open(CLKRV2)=Ok
STAUD_Init(AUD0)=Ok
STDENC_Init(DENC0, InvOut 1)=Ok
STVTG_Init(VTG0)=Ok
STVID_Init(VID0)=Ok
STE2P_Init(EEPROM) Size[2048]=Ok
initterm.c, 1552 Info> Report module is initialised ...
flashdrv.c 1908> Flash Driver Init OK
main.c 352> Lnb [8] Sat [28] Car [40] Ser [32]memdata.c 307> Eeprom End Offset [512]
memdata.c 332> eDBE Box Info Size [28]
memdata.c 363> User Box Info Size [52]
memdata.c 394> Wakeup timer Info Size [224]
***************************** MPEG - ModuleInfo *****************************
      Platform Id   - STi5518
      Toolset Used   - DCU 1.8.1
      Compiled On    - Jan 28 2003 at 15:21:24
      MPEG Module Version   - Ver 1.3.14 Rev.0
VIDEO Matrix initialisation
stv6400.c 799> successfully created video matrix process
HWC_AVMATRIX_InitModule()= OK
vpwmctrl.c 215> Install PWM interrupt 11 at level 1
Res Start Address = C0783000
Res Data - 544F4F52 4F4C425F 00004B43 C0081238
   ||    eGOS Version 2.2.33.0         ||
   || PLATFORMID 551x Date Apr 21 2003 Time 11:55:17   ||
main.c 1118> Success in creating Common User interface
main.c 573> RF => CH No. [35], O/P Mode [1]
Summary of SDB:-
   Name BlkStart PLStart #Records
    Lnb C07EAE70 C07EAE80 7
    Satelli C07EAED4 C07EAEE4 10
    Carrier C07EAFFC C07EB00C 136
    Service C07EC32C C07EC33C 406
_-_-_-_-_ eIRRXVer3.1.0.0 May 31 2003 14:57:20 _-_-_-_-_
mmi.c 260> Success in creating IR Receiver Thread
fpkeys.c 424> FPKeyBoard Thread created @[6] with StkSize[3072]
########      AFTER MMI CREATE()
Major[2] Minor[2] Build[33] Platform[551x]Toolset[DCU Version] Date[n] Name[3]
Version of May 31 2003 at 14:49:20
Built for Chip STi5518 in board CPU Clock Speed = 81000000
System initialised - hit return to enter testtool
Heap Remaining : Start[C03D53EC] End[C03FDBEC] Size[162 Kb]
Heap Remaining In SYSTEM PARTITION: Start[C01D011C] End[C030591C] Size[1267712]
main.c 754> Lnb [8] Sat [28] Car [40] Ser [32]
= eDEMOD1.0-STV0299 Build R1.1.9May 31 2003 14:58:43 =
hwc0299.c 4125> TUNER (STV0299) Module Initialisation
Creating TUNER module semaphores ...
LNB Power Control by CPU PIO[2000C000] [20]...
LNB Polarisation Control by CPU PIO[2000C000] [40]...
Selecting Tuner ... Type[0D] Addr[C0]
nsfilter.c 3400> SECTION FILTER Driver version[HWC_SFILTER_55xx/3.0 May 31 2003 14:59:31.]
nsfilter.c 3419> Successfully intialised the Circular buffer Manager ...
nsfilter.c 3552> Creating SFILTER MONITOR Process @[9] WS[9216]
NO_OF_SIMULTANEOUS_FILTERS => 32
FILTER_DEPTH_SIZE => 14
MAXIMUM_NO_OF_STREAMS => 32
nsfilter.c 3633> Succesfully Installed SFILTER module
NDB Ver 1.7.4 built on May 31 2003 15:00:42
NAVDVB       Ver 1.2.6
BUILDER    Ver 1.2.9
STORAGE    Ver 1.2.2
MEMORY       Ver 1.2.2
DEBUG       Ver 1.0.3
ndbfcm.c 4366> Database successfully initialised
irdmon.c 449> Creating IRD @(5) WS[3072]
irdmon.c 499> IRDMON successfully created
navdvbif.c 379> Initialising Teletext...
         eTTXT - 4.4.0T3
          27/05/2003
Started Initialising...
Successfully Initialized Teletext Driver.
navdvbif.c 385> Opening VBIAppl ...
navdvbif.c 441> Initialised Audio WatchDog module ...
watchdog.c 697> Created the WD_Thread @12 Stk[4096]
navdvbif.c 457> Initialised HW watchdog module ...
dvbmmi.c 635> Successfully created TIMER_Thread
is there a compatible path for this receiver?
thank you!! PLEASE UPLOAD!!
Share this post
Link to post
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
