Jump to content
Electronics-Lab.com Community
cunonstant current load
i need to build a constant current load, to demonstrate that if a constant current passes trough a capacitor, then the voltage across it increases or decreases liniary.
the problem is that i don't know how to build this.
the caps will be charged to max 16V, and if i can get a constat load over an interval of about 5V then it is very good.
but how can i build such a circuit?
i know that if it connect a LED trough a BF256 transistor, and connect the gate with the source, then the current maintained trough the led is between 10 and 15mA for voltage from 5 to 30V.
but how can i make a circuit that draws 1mA??
any help is much apreciated.
Link to comment
Share on other sites
I hope I am not misunderstanding you, but ohm's law is the rule no matter what the circuit is. V/R=I. You must take into consideration the resistance of the total circuit. If the resistance of your circuit changes or the voltage changes, then the current will change according to the formula. In regards to capacitors, the energy (in joules) stored in a capacitor is given by the formula E= 1/2(C*(Vsquared)).
Here is a link that goes into more detail about capacitance. Perhaps this will help you complete your project.
http://en2.wikipedia.org/wiki/Capacitance
Please let us know about the results. :)
MP
Link to comment
not quite like that. you see, considering the capacitor charged, it has a stored amount of electricity Q=C*U. and an energy of E=C^2*U/2 . now,
Q=I*t, where t is time and I is the current trough the cap.
if you discharge the cap trough a resisotor than I=U/R
but U changes because the cap discharges. U=Q/C, but Q2=Q-I*t
so U=(Q-I*t). if I is constant, than the voltage across the cap is decreasing in a liniar way.
but if you discharge the cap trough a simple resistor, than I drops with the dropping of U. this way thec voltage on the cap decreases slower and slower.
now....what i need is a circuit that can draw a constant current, even is the voltage applied on it is variable(of course, in limits).
Link to comment
Then you are probably looking for application using a Transconductance Operational Amplifier (OTA) such as the CA3080A or similar.
This device can be used like a variable resistor by the control pin. It is used widely in music applications for effects filtering circuits and VCA applications.
MP
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
