Jump to content
Electronics-Lab.com Community
Rolls-Royce Show Engine Motor Controller
Hello people
I have got the task of building a show engine for the new Rolls-Royce Phantom. The engine is motorised and is going to be powered with a 220v single phase 50Hz supply. The motor will have a rating of about 3kW. I would like to vary the speed of the motor using the cars throttle pedal. The pedal uses a hall sensor (i think this is the same as a variable resistor but with no physical electrical contact. The pedal is supplied with 5v and has an output of between 750mv and 4500mv. Can anybody help me design a circuit to control this motor?
Link to comment
Share on other sites
What you might be looking at is a Throttle Position Sensor (TPS). This is used to tell the on-board computer the position of the pedal in order to make other decisions such as what gear to change in the auto transmission or to richen the fuel mixture. I am not familiar with this particular engine but I do have overall experience with automotive computers in general. I have found that the best way to control the throttle on these engines without causing other errors is to connect a cruise control servo to the throttle link at the carb or fuel injection and control the servo with electrical pulses.
MP
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
