MP
Data Sheet K818, K819 and BD705, BD708
Does anyone have a cross reference chart for KT818, KT819 and BD708, BD705 transistors? For example, is there a TIPxx equivalent or 2Nxxxx equivalent that can be used in their place?
MP
Share this post
Link to post
Share on other sites
I have exhausted my sources for a cross on the above mentioned transistors. Any help would be appreciated....or if anyone knows the specs, I can find something similar from this information.
Again, any help would be much appreciated.
MP
Share this post
Link to post
Does this NTE cross reference give you what you want:
http://nte01.nteinc.com/nte/NTExRefSemiProd.nsf/$$Search?OpenForm
It comes up with an NTE equivalent for each one you listed and maybe you can get the specs from the NTE part datasheets?
Does that help? Sorry if this isn't what you wanted. I'm still learning this stuff.
Share this post
Link to post
KT818
http://elhelp.h1.ru/sprlist/c_tranz.htm
KT819
http://www.diyaudio.com/forums/showthread/t-22438.html
BD708
http://eu.st.com/stonline/books/pdf/docs/4134.pdf
http://www.st.com/stonline/books/pdf/docs/4134.pdf
BD705 TRANS NPN 12A 45V 75W TO220 use BD711-MBR
http://www.st.com/stonline/books/pdf/docs/1678.pdf
Share this post
Link to post
:)steven, mp i to had a look through my circiuts on the transisters you described and there missing from the list, if they aint discontinued. i dont know why the info on them aint so freely avaliable,
Share this post
Link to post
:)i did some searching on the net well the bd 708 transistor, complimentary silicon power transistor, is produced by s t microelectronics, cant access the data sheetsb the bd705 is what hotwater wizard sys it is as i found the same info . the k818 and k819, theres nothing i can kind on them ,
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
