MELTOKHY2004 Posted April 4, 2004 Report Share Posted April 4, 2004 NEDD DATASHEET & APPLICATION FOR IC (SAD 1024) Quote Link to comment Share on other sites More sharing options...
MP Posted April 4, 2004 Report Share Posted April 4, 2004 The SAD 1024 is a "Bucket Brigade" analog delay chip made by Reticon, discontinued several years ago. It is obsolete and you will not find one except in some rare surplus lots. If you happen to have one, you will find that they were used primarily for flangers, chorus, and echo music effects. I do not think I have an electronic copy of the data sheet but I am sure I have a hard copy somewhere. I will look around for the hard copy and see what it will take to turn it into an electronic copy if no one else posts one to this forum for you.What do you mean by "you need an application" for the chip?MP Quote Link to comment Share on other sites More sharing options...
hotwaterwizard Posted April 5, 2004 Report Share Posted April 5, 2004 This will help you for sure!http://www.geofex.com/sad1024.htmhttp://www.du.edu/~etuttle/electron/elect39.htmDatasheet Attached.SAD512-1024.pdf Quote Link to comment Share on other sites More sharing options...
Guest Kasamiko Posted April 5, 2004 Report Share Posted April 5, 2004 I'm not sure if it can be replace with MN1024.. ??? Quote Link to comment Share on other sites More sharing options...
MP Posted April 5, 2004 Report Share Posted April 5, 2004 Not directly replacable by the MN1024, but you could use it instead if you lay out a different circuit board. It uses a different pin out and clock ckt. The SAD1024 was very prone to circuit noise whereas the MN1024 was not. In fact, the SAD chip was so bad with noise that you would almost always see a compander used in conjunction with it to get rid of the noise.BTW, the MN1024 is also obsolete. The digital delay lines took over, although this was after I quit fooling with these chips so I am not familiar with what is presently the popular delay line.Perhaps someone would like to continue this discussion in the "Circuit Ideas/Requests" area of this forum.MP Quote Link to comment Share on other sites More sharing options...
hotwaterwizard Posted April 5, 2004 Report Share Posted April 5, 2004 here is one for sale on ebay.http://www.summitcellularcenter.com/SAD1024-BUCKET-BRIGADE-DELAY-IC-NEW-RETICON,i3714117096,c41415.htmlOr you can Buy one here!http://www.smallbearelec.com/Ordering/Stocklist.htm Quote Link to comment Share on other sites More sharing options...
