Guest Kasamiko
"LF" SMD code
Guest Kasamiko
Hi mate..
I check some website of SMD codebook like this one:
http://www.tkb-4u.com/code/smdcode/smdcodeL.php
but can't find any code for this devices.
It's a 3 terminal SOT-23 transistor with this marking "LF".
Any info might help.
Share this post
Link to post
Share on other sites
This is a package outline for SOT-23 package
http://www.maxim-ic.com/cgi-bin/packages?pkg=6%2FSOT23&Type=Max
LF = NPN if my German is correct check here!
http://www.fed.de/mailarchive/fed-forum/2002-01/3032.html
It is Translated as:
Honoured colleagues,
I look for the type names and the manufacturer of two bipolar
transistors in the SOT-23-Gehaeuse. The construction unit codes read:
"MF" on a PNP transistor "LF" on a NPN transistor
The Pinning is the equivalent BC848/858. Both transistors are from the same manufacturer, since the
construction unit surface and the stempeldruck are perfectly
identical.
Who can help me here? Thank you in advance for each support.
With kind regards
Now here is the Datasheet for the transistor he mentioned.
http://www.semiconductors.philips.com/acrobat/datasheets/BC846_BC847_BC848_5.pdf
Share this post
Link to post
Guest Kasamiko
Thanks John..I'll try that device and post the result here.
Thanks again.
rHoNnZ
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
