HoLoDuKE_za Posted April 19, 2005 Report Share Posted April 19, 2005 I should've been more clear about what I said earlier. - I built the project according to the schematic and not the PCB. - Afterwards, I realized that the schematic and the PCB on this website don't correspond.- I then changed the project to correspond to the PCB layout.In response to audioguru's questions:1) I used an LM324, 14-pin IC as a substitute, instead of the "IC1 = Quote Link to comment Share on other sites More sharing options...
audioguru Posted April 20, 2005 Report Share Posted April 20, 2005 Hi Duke,Your LM324 should work fine in this circuit.I see what you mean that the schematic and the PCB in this project don't correspond.I think both the schematic and pcb are wrong and the circuit will work well if you re-build it to agree with the VCO on the LM324 datasheet: Quote Link to comment Share on other sites More sharing options...
HoLoDuKE_za Posted April 21, 2005 Report Share Posted April 21, 2005 Hi audioguru and all o' ya...I think that the mistake I made initially was to assume that the schematic is incorrect and not the PCB. I built the whole project *on breadboard*, according to the schematic. I would suppose that this is why it wouldn't work. When dealing with such high frequencies such as 1MHz-1GHz, breadboard testing won't work...Fore sure, I know that there is an error on the schematic (D1 is used to label a capacitor) but I dont know whether the schematic was indeed the right one for this project.The strange thing is that when I checked the schematic on the 'Smartkit' website, I found the very same schematic for Kit #1154.Think I'll try a new approach and let you all know my results.Thanks again..The Duke,South Africa Quote Link to comment Share on other sites More sharing options...
audioguru Posted April 21, 2005 Report Share Posted April 21, 2005 Hi Duke,Sometimes kit-makers put errors on purpose on their schematics and pcb patterns to stop people from simply copying them. It is fun for me to try to re-engineer what is correct.Besides the opamp wiring and parts differences, all around the diode looks odd.The RF section of this project belongs on a tightly layed-out pcb to work at those extremely high frequencies. It hardly has any RF gain, maybe to avoid picking-up radio and TV stations, so I don't expect it to be very sensitive. ;D Quote Link to comment Share on other sites More sharing options...
Olihou Posted April 24, 2005 Report Share Posted April 24, 2005 Hi Audioguru and every bodyI am curious at the thinking that kit-makers put errors in their products purposely -- and if the kits would not work -- would that defeat their intention to sell the kits -- so they have protected their intellectual properties -- but not their businesses ?I have experience in using kits only a few times and am lucky that I succeed every time. It is nice to have some one in this forum poiting out the traps, saving the headache of many ..... Quote Link to comment Share on other sites More sharing options...
audioguru Posted April 24, 2005 Report Share Posted April 24, 2005 Hi Olihou,I don't think the kits have errors, only the schematic and/or the pcb pattern so that circuits and pcb's copied from them don't work, but the kits work fine. ;D Quote Link to comment Share on other sites More sharing options...
Olihou Posted April 30, 2005 Report Share Posted April 30, 2005 I see. Thanks a lot Audioguru ! Quote Link to comment Share on other sites More sharing options...
maroela Posted May 16, 2005 Report Share Posted May 16, 2005 i have purchased the electronic eavesdropping devices detector kit, assembled it, but it doesnt work. I checked if all the components were in the right place, and it seemed all to be in order. Could there be a problem with the kit, or is there something I could have done wrong? Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 16, 2005 Report Share Posted May 16, 2005 Hi Maroela,Welcome to our forum. ;DDoes the speaker make a sound when you turn-up the sensitivity?What radio transmission are you trying to detect?Please measure the voltages at the outputs of the opamps and the collector of TR1 and post them here. Quote Link to comment Share on other sites More sharing options...
maroela Posted May 17, 2005 Report Share Posted May 17, 2005 the speaker makes no sound at all, no matter what I do to the sensitivity. I am just trying to detect a normal FM bug. Its going to be part of a university project. my multimeter broke a few days ago, so i will not be able to give you those readings. As this is quite urgent ( it needs to work by tomorrow!), please could you give me any advice that might work. Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 17, 2005 Report Share Posted May 17, 2005 Hi Maroela,Maybe the circuit isn't sensitive enough to detect the low power of an FM bug.Try to detect a cell phone.Maybe the kitmaker supplied 2N2222 transistors with a plastic case. To be certain that you have installed them correctly, compare the pins of the metal case on the kit's layout diagram with this comparison picture showing both: Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 17, 2005 Report Share Posted May 17, 2005 I have corrected the schematic for the Electronic Eavesdropping Devices Detector project so that it is the same as the project's pcb and parts layout diagram, and is also the same as National Semiconductor's schematic: Quote Link to comment Share on other sites More sharing options...
maroela Posted June 1, 2005 Report Share Posted June 1, 2005 hey audioguru, thanks for all your help, i played around with the circuit for a while, and im not sure exactly how i did it, but i eventually got it to work. Ill probably speak to you again on another forum, cheers! Quote Link to comment Share on other sites More sharing options...
audioguru Posted June 1, 2005 Report Share Posted June 1, 2005 You're welcome, Mareola. ;DIts great to hear that you got it to work. Quote Link to comment Share on other sites More sharing options...
MP Posted June 6, 2005 Report Share Posted June 6, 2005 I am curious at the thinking that kit-makers put errors in their products purposely -- and if the kits would not work -- would that defeat their intention to sell the kits Quote Link to comment Share on other sites More sharing options...
webharsh Posted May 9, 2006 Report Share Posted May 9, 2006 hi i like the circuit . can u suggest amodification so that it can detect IR frequencies. :) Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 9, 2006 Report Share Posted May 9, 2006 Hi Webharsh,Welcome to our forum. ;DThe circuit amplifies and detects very high frequency radio signals. More amplification won't allow it to detect IR which is light that cannot be seen.To detect IR you need a light detector such as a photodiode, phototransistor or IR receiver IC. Quote Link to comment Share on other sites More sharing options...
webharsh Posted May 10, 2006 Report Share Posted May 10, 2006 so can we connect a photodiode with the circuit , to detect IR signals ? if yes then how ? Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 10, 2006 Report Share Posted May 10, 2006 so can we connect a photodiode with the circuit , to detect IR signals ? if yes then how ?Of course not. This is a high frequency radio circuit. IR is light, not radio and is modulated at low frequencies.For years, IR remote control uses an IR receiver IC.What do you want to do with IR? Quote Link to comment Share on other sites More sharing options...
webharsh Posted May 10, 2006 Report Share Posted May 10, 2006 actually i want a circuit that can detect IR frequencies . Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 10, 2006 Report Share Posted May 10, 2006 IR is a form of energy, it doesn't have a frequency that is tuned. Anything with some heat in it transmits IR. The sun transmits a lot of IR as do stoves and fires. Your body transmits some IR.You must say how strong is the IR you want to detect.IR is analog modulated with sound and is used for wireless music and language translation.IR is also digitally modulated with codes for remote control.Which do you want to detect? Quote Link to comment Share on other sites More sharing options...
webharsh Posted May 10, 2006 Report Share Posted May 10, 2006 thanks . the one which is modulated with sound . Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 10, 2006 Report Share Posted May 10, 2006 This one has the sound frequency-modulating an IR carrier of about 100kHz: Quote Link to comment Share on other sites More sharing options...
webharsh Posted May 15, 2006 Report Share Posted May 15, 2006 hi . thnx for ckt . u call ur ckt eavesdropper detector but the ckt detect any radio freq in range 1-1000 mhz.????? Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 15, 2006 Report Share Posted May 15, 2006 I don't know how sensitive is the Electronic Eavesdropping Detector. It might just pickup every radio and TV station, and taxi cab radio in town. Quote Link to comment Share on other sites More sharing options...
