patrickj Posted June 4, 2004 Report Share Posted June 4, 2004 hi i have a problem i have 2 dc motors working as a left and right 1 motor and the other working as a tilt up and down.Both these motors are in a concealed unit controlled by a electrical joystick.Can any 1 help me make the motors work wireless.Also these motors work as variable speed with contollers i.e the further right you push the joystick the faster the motor goes and the less you push the motor right the slower it goes. Quote Link to comment Share on other sites More sharing options...
audioguru Posted June 5, 2004 Report Share Posted June 5, 2004 Patrick,It will be fairly easy to control 1 motor at a time with IR, and a switch to select which motor.But it is very difficult to design an IR circuit that must share signalling of 2 motors simultaneously.Can you post a schematic of the whole circuit and the speed controllers? Quote Link to comment Share on other sites More sharing options...
audioguru Posted February 17, 2015 Report Share Posted February 17, 2015 This thread started and stopped 11 years ago.Today cheap remote controlled helicopter toys use two rotors and have a speed control for each for up, down and turning. They also have a speed and direction control at the rear for forwards and backwards. Quote Link to comment Share on other sites More sharing options...
Guest liquibyte Posted February 17, 2015 Report Share Posted February 17, 2015 It was just a spammer passing through, no worries. Quote Link to comment Share on other sites More sharing options...
