Pat09 Posted May 4, 2005 Report Share Posted May 4, 2005 Is there any way i can get a clip from a song to play whenever i open up a metal box (2x1x1/2 ft) im making. Thanks for any suggestions.p.s. if any1 has some cool electronic ideas for the metal box feel free to post. Quote Link to comment Share on other sites More sharing options...
spleblem Posted May 4, 2005 Report Share Posted May 4, 2005 hi you could try putting a small push off unpush on swith on the inside near the lid to when you lift the lid it turns on[move]spleblem[/move] Quote Link to comment Share on other sites More sharing options...
Shahriar Posted May 4, 2005 Report Share Posted May 4, 2005 Dear spleblem The best way is using UM66 IC. It is very small and funny with just Three Leads. it is very similar to an ordinary transistor thatyou may mistaken it with a transistor. It has three leads, two for Power and On for the Output. each IC has a unique code that represents the melody it has in its memory. U can test it by just connecting 3 Volts to the power leads and connect the output to your PC Line in without any extra hardware. Just do not forget to enable your Sound card Line In.P.S. because the power is 2-3.5V you can run it by watch batteries. (BT66 is the same as UM66)HTH - shariar Quote Link to comment Share on other sites More sharing options...
steven Posted May 11, 2005 Report Share Posted May 11, 2005 ;)use a small micro switch under the lid, you can find microswitches inside microwave ovens and all kinds of other electronics stuff Quote Link to comment Share on other sites More sharing options...
