Jump to content
Electronics-Lab.com Community
Sign in to follow this
Pat09
Sound Project
Is there any way i can get a clip from a song to play whenever i open up a metal box (2x1x1/2 ft) im making. Thanks for any suggestions.
p.s. if any1 has some cool electronic ideas for the metal box feel free to post.
Share this post
Link to post
Share on other sites
Dear spleblem
The best way is using UM66 IC. It is very small and funny with just Three Leads. it is very similar to an ordinary transistor that
you may mistaken it with a transistor. It has three leads, two for Power and On for the Output. each IC has a unique code that represents the melody it has in its memory. U can test it by just connecting 3 Volts to the power leads and connect the output to your PC Line in without any extra hardware. Just do not forget to enable your Sound card Line In.
P.S. because the power is 2-3.5V you can run it by watch batteries. (BT66 is the same as UM66)
HTH - shariar
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
