harrychoo Posted September 20, 2005 Report Share Posted September 20, 2005 Hi all,Can I know the way to measure main AC (240V)?If i using multimeter, can i randomly put the + and - probes on the neutral and live line?If i want to see the main waveform, what device should i use? If normal oscillocope able to do this without burning it? Or i need some special device or probes?Thanks Quote Link to comment Share on other sites More sharing options...
Staigen Posted September 21, 2005 Report Share Posted September 21, 2005 HiA little warning here! If you connect the common ground to the AC Neutral you can get a ground loop, and if you dont do that, you dont measure the true AC line! Also, if you accidently connect the oscilloscopes common ground to the AC live terminal you get a short! This will probably lead to destruction of the oscilloscope! To avoid this, use an insulation transformer between the mains and the input to the oscilloscope. And, for safety of the scopes input stage, use a high voltage probe, some scopes can not handle the peaks on the mains!//Staigen Quote Link to comment Share on other sites More sharing options...
harrychoo Posted September 22, 2005 Author Report Share Posted September 22, 2005 If i using transformer to step down the main voltage, will the output AC waveform exactly same as the input AC from main??I heard that floating can be done on the oscilloscope in order to probe the 240VAC main. Another method is using differential probe.Am i right? How to do the both methods above?Thanks Quote Link to comment Share on other sites More sharing options...
