audioguru Posted March 14, 2006 Report Share Posted March 14, 2006 BTW, the pics that Logan uploaded, like this one http://www.electronics-lab.com/forum/index.php?topic=6022.msg37411#msg37411, is it a program, and if so, whats the name, and how to get it?It is an experiment in Chapter 7, Volume VI at www.allaboutcircuits.com . Quote Link to comment Share on other sites More sharing options...
logan_dslasher Posted March 14, 2006 Author Report Share Posted March 14, 2006 i have spent all day working on the project. at the very last stage of assembling it, i encountered a problem. the inverter input LED doesn't turn ON even if i apply a high to it.. i've traced evferywhere for the fault but found none.. maybe, i'm just too exhausted, so i tried to unwind by playing online games.. i think i'm ok now.. i'll figure out somehow what is wrong..just a question, one of the LED is not very bright.. it is connected by a foot-long wire. should i shorten it? how about my question about TTL vs CMOS? can they go together in a single circuit?thanks all for all the help.. Quote Link to comment Share on other sites More sharing options...
audioguru Posted March 14, 2006 Report Share Posted March 14, 2006 Swap the LEDs. If one side is always dim then the circuit on that side has a problem. Maybe the circuit for the bright side has a problem instead.TTL and Cmos logic devices are completely different:1) TTL operates from a 5V supply only. Ordinary Cmos operates with a supply from 3V to 15V or 18V.2) A TTL input needs a high current to drive it low. An ordinary Cmos output can't supply enough current.3) A Cmos input needs a fairly high voltage for it to be high. The output voltage of a TTL device doesn't go high enough. Quote Link to comment Share on other sites More sharing options...
logan_dslasher Posted March 15, 2006 Author Report Share Posted March 15, 2006 the problem i encoutered with my inverter was due to the damaged IC.. remember, when i was working on the whistle responder circuit, i used some of the left over parts in making this project.. after i solved the inverter problem, the OR stage malfunctioned.. it's output was always low.. i have solved the problem.. i used the same technique that revealed that my 4081 was defective, since both the 4071 and 4081 have the same pin config, i replaced my 4071 with a 4081. the 4081 worked properly, therefore, the connection was fine. i replaced my 4071 with a new one. it worked fine.. why do ICs gets so easily damaged?i finished the whole project just in time... i hope my friend will have a good grade.. and i'm pretty confident he would. 8) thanks you guys..on the other hand, i learned a lot too.. he said the next project they have to pass is an AM radio receiver..tahnks again for the help.. Quote Link to comment Share on other sites More sharing options...
