Jump to content
Electronics-Lab.com Community
Sign in to follow this
Bear
Current monitor/sensor
ia have one question regarding heatsink temperature, so i have two IRFP460 mosfet on pretty big heatsink en testing on 4A current and i measured temperature on heatsink after one hour arround 80 degrees, so high. I made calculation and says:
P_Dmax=5A*(12V-(5A*0.1Ω)-5V)=5A*6.5V=32.5W
So max power dissipation is one transistor is 32.5W, thermal resistance THj-c is 0.45C/W. why then so high temperature, i select pretty bigger heatsink that it sould be regarding my calculations??
Share this post
Link to post
Share on other sites
Simple arithmetic error.
5A x 0.1 ohms= 0.5V. 12V - 0.5V= 11.5V. 5A x 11.5V= 57.5W.The heatsink thermal resistance might be 1 degree C per Watt and the thermal grease might be 0.5 degrees C per Watt. The ambient might be 30 degrees C. Then the heatsink will be very hot and the chips inside the Mosfets might be hotter than allowed.
Share this post
Link to post
Yes, but what with 5V voltage drop on 0.5E dischatge resistor? Is this nedd to take into account, or? Now i tasted with 4A, so 2A only through each mosfet and i measured 75degree per C on heatsink so from calculation is junstion temperature is allowed range.
Is that not truth?
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
