pier Posted December 29, 2006 Report Share Posted December 29, 2006 My parallel port is not working . some one said that it is blown off and another said try change the mother board . Could you suggest me to check what is the actual problem Regards Pier Francis Quote Link to comment Share on other sites More sharing options...
electrobars2006 Posted February 18, 2007 Report Share Posted February 18, 2007 Hi..i have a experience like that in my pc, re-format your pc so that the Bios detect and load the software that needed to run functionally all the ports in your mother board.RICHARD BARCELO Quote Link to comment Share on other sites More sharing options...
kruno Posted April 23, 2007 Report Share Posted April 23, 2007 My parallel port is not working . some one said that it is blown off and another said try change the mother board . Could you suggest me to check what is the actual problem Hi Pier.First check in motherboard bios is LPT port enable?If does check device manager -status LPT port.If it seems to be OK,then try to reformat HDD(before it take a backup..)Good luck,KrunoRegards Pier Francis Quote Link to comment Share on other sites More sharing options...
esp1 Posted April 23, 2007 Report Share Posted April 23, 2007 hi pier,If your PC's parallel port is not accepting commands, it maybe your operating system.Are using Win XP?, if yes, then it will block access from your program to the port.If required download from the web 'inpout32.dll' and place it in the Windows/System directory.Also check your PC's port Bios settings at boot up, the parallel port has a number of optional settings. Quote Link to comment Share on other sites More sharing options...
pier Posted May 14, 2007 Author Report Share Posted May 14, 2007 Hello ESP Actually I have connected the printer to it . My printer prints its test page but nothing from the comp . The computer also displays its printing, But the printer prints nothing. I have bought a new one but still have the old mother board. My local hardware fellow told me to change the mother board or get it fixed which would cost me almost 75% of the new one and so i went for a new one . If suggessions are given from the community i would like to work on that personally . My bios settings are right . Quote Link to comment Share on other sites More sharing options...
esp1 Posted May 14, 2007 Report Share Posted May 14, 2007 hi pier,If you have a spare slot in your PC, you could get anotheer Parallel port pcb fairly cheap, use LPT2.Can you try connecting YOUR printer to a friends PC for a test and vice versa? Quote Link to comment Share on other sites More sharing options...
pier Posted May 14, 2007 Author Report Share Posted May 14, 2007 I'm sure there is no spare slot ( its an old system ) . Can you try connecting YOUR printer to a friends PC for a test and vice versa? I never thought of this idea . I will let u know tomorrow . Quote Link to comment Share on other sites More sharing options...
pier Posted May 17, 2007 Author Report Share Posted May 17, 2007 Hi Its working at my friends place . Quote Link to comment Share on other sites More sharing options...
