Sign in to follow this
Fight
LM338 Power Suply Current Regulator
In lm338 data sheet asking
Features:
Guaranteed 7A peak output current
Guaranteed 5A output current
But problem is that in Electrical Characteristics:
Vin-Vout = 30V Than max current 1A
what is meaning that
lets Vin = 38V  and Vout = 8V
38-8 = 30
and Vin-Vout = 10V or less than 5A can handle
mean
38-28 = 10
mean 8 to 28V 1A handle
and 28 to above 5A handle
Attatch Diagram
2.    in Application Hints diagram all diagram is designed that can handle 5A
Attatch Diagram
Share this post
Link to post
Share on other sites
Exactly what are you wanting to do here?
You Must Heatsink the components for 5 amps each if not they will only handle 1 amp each.
There is another way to make a high current power supply.
That circuit will have very poor regulation because the base-emitter saturation voltage of the 2N3055 will vary depending on the current drawn and the 0.47R resistors will have a significant voltage accross them.
Suppose the current draw is 0A and you set the voltage to 12V.
Then you increase the current to 5A.
@0A the VBE of the transistors will be near 0.6V.
Each transistor will have 5/6 = 833mA through it, the same for the emitter resistor.
The voltage will drop by the 0.47R resistor will be 5/6
Share this post
Link to post
They help to ensure the current is shared equally between the transistors. The value isn't critical, I chose 0.1R because I originally designed it for high currents, for 5A you can use 1R which will be easier to get hold of.
Share this post
Link to post
Changing the value will not change the current, the circuit does not provide current regulation, it's just that if the voltage drop across the resistors is very low, the current sharing won't be very good.
Share this post
Link to post
please explain it using examples
if 10R resistor use than
Share this post
Link to post
There's no hard and fast rule, I just use current balancing resistors which have a voltage drop of a couple of hundred mV or so at full current. The voltage drop can be calaculated using Ohm's law.
what is the efficiency of these circuit
It's as efficient as an linear regulator.
if this method using with lm317 and lm338 than thses ic better current and voltage or not
Share this post
Link to post
ok
Quote
my mean that if using transistor current increasing method for lm317 or lm338 regulator ic than this method ok or not because volatge vary from 1.2 to 30 v
7805 or 7812 is fixed regulator
Share this post
Link to post
Attatch diagram
first circuit is use for current limiting
transiter is use for current increasing transistor current provide 5A at all voltage range 1.2-30V
this circuit is good
better
best
or not
Share this post
Link to post
than any idea for increasing current
and tell me that this circuit provide good current limiting and
5A current provide at all voltage range 1.2 to 30V  and
good voltage regulation from 1.2 to 30V
if 0-30V instead 1.2-30V than modification on circuit
Share this post
Link to post
It's not a very good idea because the extra regulator will increase the drop out voltage by 4.2V.
where 4.2V drop
2V drop across IC 1 that for current limiting/regulating
0.7V drop across BE resistor
2V drop across IC 2 that for voltage regulating
i am right or not
if input voltage 38V than 4.7V drop acrosss these the output will vary easily 1.2 to 38-4.7 = 33.3V
yes or not
Share this post
Link to post
The LM338 has a drop out voltage of 3V at full current and when configured as a current regulator, the voltage reference of 1.25V across the current sense resistor, adds to it making 4.25V.
Share this post
Link to post
This circuit provide good current limiting and
if lm338 configured as voltage reglator than voltage drop across it = ?
Share this post
Link to post
It looks like you did not read the datasheet for the LM338:
1) It shows a graph of the typical dropout voltage at various currents but does not list a max dropout voltage.
2) It lists a max output current of 5A only when the Vin - Vout is 10V or less (then your minimum output voltage is 23V. It lists its max output current to be only 1A when Vin - Vout is 30V.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
